DAYTON AUDIO M6 Active Bookshelf Speakers Black (Pair)
Dayton Audio M6 active speakers are part of their M-Series range. They are based on the use of Class D amplification allowing them to develop power up to 2x 75W while offering rich sound over a wide sound band through their 16cm Signature™ Series aluminum woofer and 2.5cm tweeter. In addition to their excellent sound reproduction performance, the M6s offer extensive functionality and connectivity.
By buying this product you get 45 loyalty points
Reference : 19880
459,00 €tax incl.
382,50 € tax excl.
This product is temporarily unavailable.
Dayton Audio M6 Active Bookshelf Speakers with USB DAC/Bluetooth 5.0 2x75W 35Hz-20kHz Black (Pair)
Dayton Audio M6 photo
Dayton Audio M6 active speakers are part of their M-Series range. They are based on the use of Class D amplification allowing them to develop power up to 2x75W while offering rich sound over a wide sound band through their 16cm Signature™ Series aluminum woofer and 2.5cm tweeter. In addition to their excellent sound reproduction performance, the M6s offer extensive functionality and connectivity. Indeed, alongside their stereo RCA input, there's a USB input with integrated DAC enabling them to support 32Bit 192kHz streams, as well as a Qualcomm Bluetooth 5.0 receiver chip for high-resolution wireless transmission with SBC, AAC, aptX and aptX HD codecs. Dayton Audio has also decided to equip its M6 active speakers with a subwoofer output. These extremely versatile speakers are therefore suitable for a wide range of uses. In particular, they are perfect as desktop speakers, 2.1-channel TV speaker systems or Hi-Fi set-ups, and even feature a remote control for distant operation.
Key features of the Dayton Audio M6 active speakers:
  • 16cm (6“) woofer and 2.5cm (1”) tweeter
  • Class D amplification
  • 150Wrms power (2x75W)
  • Analog RCA stereo input
  • USB connectivity with integrated 32bit 192kHz DAC
  • Bluetooth 5.0 (SBC, AAC, aptX, aptX HD)
  • Subwoofer output
  • Bass boost function
Dayton Audio M6: powerful speakers
The Dayton Audio M6, with their class D amplification, offer 2x75W power to sound a small/medium-sized room of up to 20/30m². They feature a 2-way configuration with a 16cm Signature™ Series woofer and a 2.5cm silk dome tweeter.
Dayton Audio M6 USB input
Dayton Audio M6: built-in USB DAC
A USB input with built-in DAC lets you connect a digital source directly to the Dayton Audio M6, such as a computer or sound card with USB output.
Dayton Audio M6 : Bluetooth 5.0
The M6 active speakers also feature a Qualcomm Bluetooth receiver module for reliable, stable wireless transmission. They support high-resolution codecs: SBC, AAC, aptX, aptX HD.
Dayton Audio M6 Bluetooth functionality
Dayton Audio M6 subwoofer output
Dayton Audio M6: subwoofer output 20Hz-200kHz
A small plus, but a big advantage, Dayton Audio M6 active speakers feature a subwoofer output on an RCA connector. This makes it easy to set up a 2.1 system with an active subwoofer for deeper, more immersive sound. Whether for a gaming, TV or Hi-Fi experience, this feature is most welcome.
Dayton Audio M6: excellent build quality
Dayton Audio's expertise in the Hi-Fi market is well established. The M6 speakers benefit from a closed design and an integrated DSP which, thanks to the Bass Boost function, offers an extended low-frequency response when the user so requires. Overall sound reproduction is clear, precise and immersive. Furthermore, Dayton has chosen durable manufacturing materials and a hard-wearing matt paint finish to effectively protect them from the potential signs of wear and deterioration over the years.
Dayton Audio M6 build
Dayton Audio M6: active speakers that are easy to set up and use
On the rear panel of the driver speaker, there's a switch that lets you choose whether to position it on the right or left side during installation. This makes it easier to plug in and optimize the placement of the M6s more freely. The front panel also features a volume control potentiometer, a signal input selection LED and a remote control. The input signal selection LED uses the colors below for each indication:
  • Green : RCA
  • Orange : USB
  • Blue : Bluetooth
  • Red : Standby
Dayton Audio M6 setup and use
Dayton Audio M6's extensive connectivity
Dayton Audio M6 overview
1Input indication LED
2Multifunction button: Power/volume control/input selector/Standby
3Stereo RCA input
420Hz-200kHz subwoofer output
5USB-C input
6Speaker terminal output
7Pilot speaker position selector
8Bluetooth pairing button
9Power switch
10Power supply port
11Passive speaker
12Speaker terminal input
Product typeActive speaker
Amplification typeClass D
Configuration2-way
Speakers per enclosure1x 16cm Signature™ Aluminum series woofer
1x Silk dome tweeter
Inputs1x Stereo RCA analog input
1x USB-C input
Bluetooth
Output1x Subwoofer output (20Hz-200kHz - 300Ω)
Frequency response35Hz-20kHz
Output power2x 75W
Line input impedance7.4kΩ
Supported sample rateDAC USB : 32bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD
Power supply100-240V 50/60 Hz
Standbye energy consumption<0.5W
Dimensions190 x 230 x 300mm
Net weightActive speaker: 5.4kg
Passive speaker: 5.1kg
Gross weight12.5kg
Package1x Dayton Audio M6 active speakers pair
1x Remote control unit
1x Speaker interconnection cable (banana plugs)
1x 3.5mm jack to RCA stereo cable
1x USB-C cable
8x Adhesive rubber feet
1x Mains power cable
DAYTON AUDIO M6 Active Bookshelf Speakers with USB DAC/Bluetooth 5.0 2x75W 35Hz-20kHz Black (Pair)
Dayton Audio M6 active speakers are part of their M-Series range. They are based on the use of Class D amplification allowing them to develop power...
