IIIP Active Subwoofer 100W 4 Ohm Ø20cm
This IIIP active subwoofer features an 8" (Ø20.3cm) woofer with paper cone and rubber suspension. It is capable of developing up to 100W RMS (200W max). Integrated within your audio system, it will allow you to enjoy deep, rich and accurate bass for a transformed listening experience.
Reference : 14386
99,00 €tax incl.
82,50 € tax excl.
IIIP Subwoofer
Active Subwoofer 100W 4 Ohm Ø20.3cm
IIIP Subwoofer Actif Ø20.3cm 100W 4 Ohm
The rear panel of the subwoofer is equipped with connectors that allow integration into the vast majority of audio systems. There is also a volume control, a phase control and a frequency control. The subwoofer also benefits from the Auto ON and Auto OFF function, allowing it to turn on when it detects an incoming signal and to turn off automatically after a delay without signal.
Rear panel diagram
1Power connector (IEC)
2Power button
3Input voltage adjustment
4Auto Power ON mode button
5Phase adjustment knob
6Frequency adjustment (40-250Hz)
7Volume
8Low level RCA line input
9Mono RCA line input
10High level input
Product typeSubwoofer
Speaker driver typeWoofer 8" (Ø20.3cm)
Paper cone
Rubber surround
PowerRMS : 100W @ 4Ω, 1% THD+N
Max : 200W @ 4Ω, 1% THD+N
Nominal impedance4Ω
Frequency response40Hz - 1.3kHz
THD+N0.5% @ 100W, 4Ω, 100Hz)
SNR> 96dB
Line input sensitivity205mV
Adjustable low pass crossover46Hz - 250Hz
Low pass filter270Hz @ 30dB/oct
High pass filter28Hz @ 22dB/oct
Bass boost12dB @ 45Hz
Auto ON sensitivity3mV
Auto OFF delay22 minutes
ConsumptionStandby: 0.2W
No signal: 12W
Max: 158W
Dimensions380 x 270 x 325mm
Weight8.4kg
Package1x Subwoofer IIIP
1x Power cable
Lowest frequency (Hz)40
Highest frequency (Hz)40
Power (W)100.0
Number of loudspeakers1
Speaker typeActive
This IIIP active subwoofer features an 8" (Ø20.3cm) woofer with paper cone and rubber suspension. It is capable of developing up to...
