MINIDSP SPK-4P Active Speaker Full Range PoE+ AVB DSP SHARC 2x15W
10%
The miniDSP SPK-4P is a PoE+ full-range speaker combining audio streaming (AVB), Class D amplification and digital signal processing (DSP). A single RJ45 Cat5/6 Ethernet cable is used to power the speaker, stream audio and control the device, for a true Plug&Play experience.
Reduced price!
Reference : 16857
Limited special offer
499,00 €tax incl.
-10%
449,10 €tax incl.
374,25 € tax excl.
Shipping date: 16-04-2025.
miniDSP SPK-4P
miniDSP SPK-4P Enceinte active connectée large bande PoE+ AVB DSP SHARC 2x15W
The miniDSP SPK-4P is a PoE+ full-range speaker combining audio streaming (AVB), Class D amplification and digital signal processing (DSP). A single RJ45 Cat5/6 Ethernet cable is used to power the speaker, stream audio and control the device, for a true Plug&Play experience. The system consists of three key components:
  • Audio Video Bridging (AVB) technology, powered by a 500MHz XMOS processor, ensures very low latency and offers an uncompressed and perfectly synchronized audio stream between each speaker on the network.
  • An Analog Devices SHARC 400MHz processor is in charge of processing the signal and offers an equalization, filter and acoustic correction system. Each element is accessible and can be set via the intuitive software provided by miniDSP.
  • A new multi-level switching audio amplifier technology developed by Merus Audio allows the SPK-4P to deliver 2x15W power. This means that each SPK-4P can act as an amplifier for two speakers (master + slave).
Product typeActive speaker
Inputs1x Optical Toslink
1x Ethernet RJ45 (AVB)
DSP processor32bit Floating point Analog Devices SHARC ADSP21489 400MHz
USB / AVB processorXMOS XCore200
Output power (RMS)2*15W @ alimentation +12V
2*12W @ alimentation via PoE+
DSP SettingsFIR Filters
IIR EQ
Gain
Level
Delay
Supply voltage12VDC (45W) via Jack DC 5.5/2.1mm or PoE+ (Power Over Ethernet)
Dimensions125 * 125 * 131mm
Weight1.3kg
Impedance (Ω)NC
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Power (W)15.0
Number of waysN/A
Speaker typeActive
Speaker form factorBookshelf speaker
The miniDSP SPK-4P is a PoE+ full-range speaker combining audio streaming (AVB), Class D amplification and digital signal processing (DSP). A...
