OCTAVIO MAESTRO Connected Active Speaker Bluetooth WiFi AirPlay 2 Black
With the Maestro, Octavio unveils a superb connected active speaker, capable of delivering uncolored sound with a wide soundstage and beautiful richness. The Maestro speaker connects via Bluetooth and WiFi for lossless listening and maximum versatility, allowing you to enjoy your music from all the major streaming platforms or access files stored on your networked devices. It's compatible with AirPlay 2, Spotify Connect and Tidal Connect streaming protocols. In addition, two Maestro speakers can be connected together wirelessly to create a stereo system.
By buying this product you get 59 loyalty points
Reference : 17263
599,00 €tax incl.
499,17 € tax excl.
The MAESTRO speaker can be used in true stereo. Simply pair 2 speakers using the Virtuose application.
Octavio Maestro
Octavio Maestro Enceinte Active Connectée Bluetooth WiFi AirPlay 2 Noir
A design that leaves nothing to chance
The Octavio Maestro uses Davis Acoustics speakers with Kevlar diaphragms, ensuring a very precise sound reproduction. Light and rigid, the models used offer a beautiful musicality, with soft mids, deep bass and particularly well defined highs.
Enjoy all your audio devices
In addition to its wireless connectivity, the Maestro speaker can also be connected in the traditional way thanks to its Jack 3.5mm and Optical Toslink connectors. It is thus possible to connect any audio equipment.
An intuitive and practical application
Thanks to the Octavio Virtuose mobile application, you can access all your music directly from your favorite streaming platforms and web radios as well as all your local files. More than that, the application offers the possibility to define an equalizer and to create profiles to easily adapt the sound reproduction of your speaker.
Product typeConnected active speaker
Drivers diametersWoofer: Ø13cm
Tweeter: Ø2.5cm
Frequency response (-3dB)40Hz - 20khz
Output power70W
Amplification typeClass D
Supported wireless protocolsSpotify Connect
Tidal Connect
AirPlay 2
Bluetooth
Connectors1* Jack 3.5mm
1* Optique Toslink
1* Ethernet RJ45
Audio resolution16bit 48kHz
WiFiWiFi b/g/n
2.4GHz/5GHz
ConsumptionIn use: 14W
En Standby: 1.9W
Dimensions (L*P*H)31.5*28.5*27cm
Weight3.45kg
With the Maestro, Octavio unveils a superb connected active speaker, capable of delivering uncolored sound with a wide soundstage and beautiful...
