By buying this product you get 37 loyalty points
serious caison active 150W Class D 35-250Hz - Adjustable crossover
The subwoofer 3060S of at Q Acoustics embeds a speaker 200mm and an integrated 150W amplifier.
If he follows the aesthetic line of Q3000i series of the same manufacturer, Q3060s will work with any home cinema system to bring real depth in the bass.
The controls and connections are hidden under a magnetic hatch. The input connector is angled such a way that the plugged cable do not exceed ungracefully from the device.
The crossover and the volume are adjustable from the outer panel. The crossover can be set anytime between 35 to 250Hz.
The enclosure is built as infinite baffle. This type of housing is ideal for high-performance low-frequency speakers.
The box can be installed on a piece of furniture thanks to the four spikes provided. It can be installed directly on the floor with additionnal (non included) rubber feet as well.
Enclosure Type | infinite baffle |
Frequency response (+3 dB, -6 dB) | 35-250 Hz |
Amplification power | 150W |
frequency crossover | 35-250Hz (variable) |
Class | D |
Dimensions | 480 x 300 x 150 mm |
Weight | 8.5kg |
Package Contents | |
Active subwoofer 3060s | x1 |
Spikes | x4 |
Power cable | x1 |
User Manual | x1 |
Color | Gray |
Color | Black |
Impedance (Ω) | NC |
Loudspeaker diameter (mm) | N/A |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 35 |
Highest frequency (Hz) | 250 |
Power (W) | 150.0 |
Number of loudspeakers | 1 |
Speaker type | Active |
