By buying this product you get 39 loyalty points
Active Subwoofer Class D 150W 35-250Hz White
The 3060S active subwoofer from Q Acoustics features a 200mm driver and an integrated amplifier capable of delivering 150W of power. If it follows the aesthetics of the Q3000i series, the Q3060s will work with any home cinema system to provide true bass depth.
Controls and connections are hidden under a magnetic hatch. The input connector is angled so that the cable, once plugged in, does not protrude unsightly from the unit.
The crossover as well as the volume level are adjustable from the outer panel. The crossover filter can be easily adjusted from 35Hz to 250Hz.
The enclosure is built in infinite baffle. This type of enclosure is ideal for high-performance woofers.
The subwoofer can be installed on a piece of furniture thanks to the four spikes supplied. It can also be placed on the floor on a soft surface (rubber feet).
Product type | Active subwoofer |
Enclosure type | Infinite baffle |
Frequency response (+3dB, -6dB) | 35Hz - 250Hz |
Amplification power | 150W |
Crossover frequency | 35Hz-250Hz (variable) |
Amplification class | Class D |
Dimensions | 480 x 300 x 150mm |
Weight | 8.5kg |
Color | White |
Package | 1x Q Acoustics 3060s 4x Spikes 1x Power cable 1x User manual |
Color | White |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 35 |
Highest frequency (Hz) | 250 |
Power (W) | 150.0 |
Number of loudspeakers | 1 |
Speaker type | Active |
