RUARK AUDIO RS1 Active Subwoofer Walnut
Ruark Audio's RS1 is an aesthetically pleasing 100W active subwoofer. Its 17cm diameter driver, accompanied by a 17cm passive radiator, delivers natural, extended bass over a frequency range from 25Hz to 200Hz.
By buying this product you get 39 loyalty points
Reference : 20043
399,00 €tax incl.
332,50 € tax excl.
Ruark Audio RS1 Active Subwoofer Class D 100W Ø17cm Walnut
Ruark Audio RS1 : 3/4view
Ruark Audio RS1: 100W amplification
The system is driven by a powerful 100-watt Class D amplifier. This new-generation amplifier perfectly controls the bass driver at all volume levels, with considerable headroom, although progressive clipping is built in if the system is overloaded to prevent damage. Set-up and adjustment are simple and, thanks to the auto-on/standby function, the RS1 switches on and off automatically as required.
Ruark Audio RS1 : Driver
Ruark Audio RS1 : example of use
Ruark Audio RS1: Meticulous aesthetics
One of Ruark Audio's design objectives for the RS1 was to create an aesthetic that is both sober and classy. The custom-made grille and walnut wood panels allow this subwoofer to blend in perfectly with other furnishings, combining visual and acoustic pleasure to perfection.
Product typeActive subwoofer
Input1x RCA mono (2.3Vrms)
Drivers1x Woofer Ø17cm
1x Passive radiator Ø17cm
Frequency response25Hz – 200Hz
Crossover50Hz - 180Hz
Amplification typeClass D
Output power100W
Phase switchYes (0/180°)
Volume controlYes
Supply voltage100-240V AC, 50-60Hz
Dimensions300 x 250 x 265mm
Weight6.7kg
FinishWalnut
Package1x Ruark Audio RS1
1x 1.5m RCA cable
1x Power cable
RUARK AUDIO RS1 Active Subwoofer Class D 100W Ø17cm Walnut
Ruark Audio's RS1 is an aesthetically pleasing 100W active subwoofer. Its 17cm diameter driver, accompanied by a 17cm passive radiator,...
