TONEWINNER SW-1000 Active Subwoofer
The Tonewinner SW1000 active subwoofer is a bass-reflex subwoofer with a 25.4cm driver delivering up to 200Wrms power at 4 ohms (THD+N<3%). The SW-1000 operates in Class H to adapt its supply voltage to the input signal for high efficiency and a constantly available power reserve.
By buying this product you get 54 loyalty points
Reference : 19257
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 25-04-2025.
Tonewinner SW-1000 Active Subwoofer 200W 4 Ohm 21Hz-240Hz Ø25.4cm
Photo of Tonewinner SW-1000 active subwoofer
The Tonewinner SW1000 active subwoofer is a bass-reflex subwoofer with a 25.4cm driver delivering up to 200Wrms power at 4 ohms (THD+N<3%). The SW-1000 operates in Class H to adapt its supply voltage to the input signal for high efficiency and a constantly available power reserve. It features a wide range of settings, including cutoff frequency, volume and 0°-180° phase inversion. Two events on the front panel enhance bass response. As for inputs, you can choose between an RCA line input or two other inputs: RCA LFE and balanced XLR.
Tonewinner SW-1000: a Ø25.4cm diameter driver
The SW-1000's 25.4cm diameter driver and two bass-reflex events enable it to handle low frequencies while limiting distortion, for an immersive Hi-Fi or home-cinema experience. A 200W amplifier stage ensures powerful, dynamic bass reproduction. The SW1000 can go down to a frequency of 21Hz.
Photo of ToneWinner SW-1000 active subwoofer speaker
Zoom in on the ToneWinner SW-1000 control panel
Tonewinner SW-1000: cut-off control, volume control and phase inversion
The SW1000 features two 9-notch potentiometers for volume and cut-off frequency adjustment. A switch allows you to invert the phase 0° or 180°, depending on the position of the subwoofer in relation to your speakers.
Tonewinner SW-1000 subwoofer overview
Overview of the ToneWinner SW-1000 subwoofer control panel
1Power-on indicator LED
2Cutoff frequency setting
3Volume control
4Phase reversal
5RCA line input
6RCA LFE input
7LFE XLR input
8Power supply voltage switch (110V - 230V)
9Fuse
10IEC power supply
11Power on/off switch
Product typeActive subwoofer
Driver diameterØ25.4cm
Amplification typeClass H (D)
Output power200W
Frequency response21Hz-240Hz
Phase adjustment0° or 180°
Impedance4Ω
Case materialMDF
Inputs1x LFE XLR
1x LFE RCA
1x RCA line input
SPL-max (dB(C), Peak, Music, 1m):107
DRIVER PARAMETER
Frame materialSteel
Voice coil diameterØ50mm
ConeSurface waterproofing semi-pressed paper cone
X-Max±12mm
Magnet size145x20x2mm
Power supply110 AC (50Hz) or 230 AC (60Hz) - Switch available on rear panel
Dimensions360x432x432mm
Gross weight21kg
Net weight19kg
Package1x Tonewinner SW-1000 subwoofer
TONEWINNER SW-1000 Active Subwoofer 200W 4 Ohm 21Hz-240Hz Ø25.4cm
The Tonewinner SW1000 active subwoofer is a bass-reflex subwoofer with a 25.4cm driver delivering up to 200Wrms power at 4 ohms (THD+N<3%)....
