TONEWINNER SW-D2000 Active Subwoofer
The Tonewinner SW-D2000 is a bass-reflex-loaded active subwoofer. This model features a large 30cm driver, powered by a 400W amplification stage. It also features a DSP for fine-tuning the subwoofer's settings to perfectly match your system and listening room. This SW-D2000 is ideal for a home-cinema installation, delivering deep, punchy bass for total immersion.
By buying this product you get 79 loyalty points
Reference : 18504
799,00 €tax incl.
665,83 € tax excl.
Shipping date: 22-04-2025.
Tonewinner SW-D2000
Active Subwoofer 400W 3 Ohm 18Hz - 240Hz Ø30cm
Tonewinner SW-D2000 Active Subwoofer 400W 3 Ohm 18Hz - 240Hz Ø30cm
30cm diameter loudspeaker
The Tonewinner SW-D2000's large 30cm-diameter driver is capable of descending very low and without distortion, to reproduce the bass of your music and films more than convincingly. It features a rigid diaphragm, limiting distortion even when the driver is subjected to considerable deflection..
The 400W amplifier stage ensures powerful, dynamic bass reproduction, enabling the subwoofer to respond effectively to the signal supplied. The SW-D2000 is thus capable of descending without difficulty to a frequency of 18Hz.
DSP and EQ
To perfectly match your audio system and listening room, the SW-D2000 comes with its own DSP and EQ directly accessible from the back of the cabinet. An LCD screen displays your settings in real time. These settings can also be accessed remotely via Tonewinner's free mobile application. Several predefined DSP modes are available, but you can also go further by customizing the subwoofer's equalization yourself.
XLR & RCA
The rear of the Tonewinner SW-D2000 features a dual LFE input in unbalanced RCA and balanced XLR formats, as well as an RCA line input and an RCA LFE output. The SW-D2000 is thus capable of integrating into the majority of home-cinema or even HiFi audio systems. What's more, its output allows the association of a second subwoofer.
1Input voltage selection
2Power button
3Power input
4Fuse
5Balanced LFE input
6Single-ended LFE input
7LFE output
8RCA line input
9Volume + / Volume -
10Mute / OK
11Menu
12LCD screen
13ON/OFF LED
Product typeActive subwoofer
Loudspeaker diameterØ30cm
Amplification typeClass D
Power output400W
Frequency response18Hz - 240Hz
Phase setting0 - 180°
Impedance3Ω
Cabinet materialMDF
DSP / EQ
Inputs1x LFE XLR
1x LFE RCA
1x RCA line in
Output1x LFE RCA
Dimensions426 x 400 x 472mm
Weight23kg
TONEWINNER SW-D2000 Active Subwoofer 400W 3 Ohm 18Hz - 240Hz Ø30cm
The Tonewinner SW-D2000 is a bass-reflex-loaded active subwoofer. This model features a large 30cm driver, powered by a 400W amplification stage....
