TONEWINNER SW-D8000 Active Subwoofer
The SW-D8000 is an active subwoofer from Tonewinner. It features two Ø38.1cm (15") subwoofers drivers with low distortion, wide linear excursion and dynamic range. It is thus capable of delivering deep, punchy bass, particularly effective within a home-cinema system for total immersion.
By buying this product you get 249 loyalty points
Reference : 18684
2 490,00 €tax incl.
2 075,00 € tax excl.
Tonewinner SW-D8000 Active Subwoofer 1500W 3 Ohm 13Hz - 220Hz Ø38cm
Tonewinner SW-D8000 : Main view
The SW-D8000 also features a powerful, high-output 1500W Class D amplifier, capable of delivering 8000W (3Ω) peak P-P power, to perfectly accompany the two large loudspeakers. The design of the drivers, with paper diaphragm, rubber suspensions, large OFC copper coil and double magnet, ensures optimum performance.
Five front-mounted vents enhance low-frequency diffusion. These can also be plugged with the supplied foams, for a closed system with improved transient response and distortion.
The whole unit is housed in a sturdy MDF case with oak-effect veneer. The internal structure of the cabinet itself is optimized to reduce standing waves.
The rear panel of the SW-D8000 subwoofer features an LCD display and four touch-sensitive buttons for adjusting the subwoofer's DSP. The SW-D8000 can also be controlled remotely using the free mobile app, via an intuitive graphical interface. Settings include a high-pass/low-pass filter, phase inversion (0/180°), 7-band parametric equalizer, trigger sensitivity adjustment, low-power mode and pass-through mode. Four profiles are also available: Deep Mode, Normal Mode, Strong Mode and User Mode (custom profile).
Connectors include an XLR balanced input, an RCA unbalanced input, an RCA line input and an RCA SW output. Finally, the SW-D8000 also benefits from a complete protection system against overload, overcurrent, overvoltage, overtemperature and short-circuit.
Tonewinner SW-D8000 : Main features
Tonewinner SW-D8000 : Schéma panneau arrière
1Supply voltage switch
2Power switch
3Power input
4Fuse
5XLR balanced input
6RCA single-ended input
7Single-ended output
8Stereo RCA line in
9Volume + / Volume - buttons
10OK / Mute button
11Menu button
12LCD screen
13LED indicator
Product typeSubwoofer
Drivers2x subwoofer Ø38.1cm (15")
Amplifier power1500W
Peal power (P-P)8000W
Frequency response13Hz - 220Hz
Supply voltage110-115VAC / 220-230VAC (switchable)
Net dimensions (L x P x H)526 x 694 x 648mm
Net weight70kg
Consumption1100W
Package1x Tonewinner SW-D8000
1x Power cable
TONEWINNER SW-D8000 Active Subwoofer 1500W 3 Ohm 13Hz - 220Hz Ø38cm
The SW-D8000 is an active subwoofer from Tonewinner. It features two Ø38.1cm (15") subwoofers drivers with low distortion, wide...
