TRIANGLE AIO TWIN Active Bookshelf Speakers Bluetooth 5.0 aptX HD WiFi 2x50W 24bit 192kHz Eggplant (Pair)
Triangle's AIO Twin active bookshelf loudspeakers are a real concentrate of technology and know-how. Versatile, with extensive connectivity, they are perfectly adapted to today's uses. They also offer excellent sound performance, revealing a rich, precise and detailed sound.
By buying this product you get 68 loyalty points
Reference : 16368
689,00 €tax incl.
574,17 € tax excl.
Triangle AIO Twin
Triangle AIO Twin Enceintes Bibliothèques Actives Bluetooth 5.0 aptX HD WiFi 2x50W 24bit 192kHz Aubergine (La paire)
Equipped with WiFi and Bluetooth 5.0 connectivity, the remote broadcasting of your music is done easily, directly from your smartphone or computer, with a resolution that can reach 24bit 192kHz. Still in this perspective of versatility, the AIO Twin has a Phono input to connect a vinyl turntable.
Triangle AIO Twin Enceintes Bibliothèques Actives Bluetooth 5.0 aptX HD WiFi 2x50W 24bit 192kHz Aubergine<span id= (La paire)" />
A versatile speaker
Hi-Res transmission : The AIO Twin allows you to stream your music in high resolution extremely simply, directly from a smartphone, tablet or computer.
Webradios & Services de streaming : With TuneIn, you can access podcasts, news, music, live sports or radio from around the world.
Phono : Enjoy your vinyl records by connecting your turntable directly to the dedicated input.
Multiroom : Install multiple pairs of AIO Twin speakers in your home to create a true multiroom audio system that can be controlled remotely throughout your home.
Audio-Video : Easily connect your TV to your speakers with the dedicated Toslink Optical input.
AIO technology
Bluetooth : Stream your music with ease with the Bluetooth 5.0 receiver, supporting aptX and aptX HD high definition transmission codecs.
WiFi : Enjoy superior sound quality thanks to wireless transmission via WiFi. It allows the reading of PCM streams up to 24bit 192kHz.
Your music always at hand
The free Triangle AIO mobile application, available on both the App Store (Apple) and the Google PlayStore (Android), gives you access to a wide range of streaming services directly from your smartphone or tablet. You can also access all your audio files stored on your device or on your local network, on a NAS or connected computer for example.
With LinkPlay technology, connect all your AIO devices on your network and control all your home audio equipment remotely, right from your app. Control the playback and playback options for each room in your home, enjoy equalizers for each room, or pair your speakers with each other.
Enjoy your favorite streaming services
The Triangle AIO mobile app also lets you take advantage of the biggest music streaming services and the vast content on offer. Use the famous platforms Deezer, Spotify, Qobuz or Tidal for their large catalogs of music or TuneIn to access web radios from around the world.
Your vinyls in all simplicity
With the AIO Twin speakers, your vinyl records won't be put away. Thanks to the on-board MM phono preamplifier, connect your turntable directly to the speakers and listen to your records with ease.
High quality materials
For these AIO Twin, Triangle offers a selection of noble materials combining both acoustic performance and aesthetic qualities. The high-density wood particle cabinetry provides great sound neutrality. Its rigidity is a key element to avoid any sound coloration.
The speakers, equipped with elegant aluminum feet with rubber feet, dissipate vibrations efficiently. The sound message and the surface of your furniture are thus preserved
Partnership with Maison Gabriel
For several years now, Triangle has partnered with Maison Gabriel for the production of its speaker grilles. A true specialist in high quality fabrics, the brand offers a wide range of colored and textured finishes. Thus, the AIO Twin grille uses Bond fabric, a quality fabric with a unique look, in harmony with the different finishes of the cabinetry. The oblong shape of the grille makes the AIO Twin a real decorative object.
Product typeActive speakers
DriversTweeter 25mm
Woofer 13cm
Power handling2x50W
NetworkWiFi IEEE 802.11g/b/n 2.4GHz RJ45 10/100M LAN
Supported sampling ratesPCM jusqu'à 24bit 192kHz
Bluetooth version5.0
Supported Bluetooh codecsAAC, SBC, aptX, aptX LL, aptX HD
InputsWiFi
1x Stereo RCA
1x Jack 3.5mm
1x Optical Toslink
Bluetooth
1x USB-A (USB Host)
Outputs1x Subwoofer output
Frequency response56Hz - 22kHz
Supported audio formatsAPE, FLAC, WAV, Apple Lossless (ALAC), AAC, AAC-LC, HE-AAC, HE-AAC v2, MP3, CBR/VBR
Dimensions165 x 304 x 235mm
Weight10.4kg (paire)
ColorEggplant
QuantityPair
ColorViolet
Impedance (Ω)NC
Lowest frequency (Hz)56
Highest frequency (Hz)22000
Power (W)50.0
Number of ways2
Speaker typeActive
Speaker form factorBookshelf speaker
Triangle's AIO Twin active bookshelf loudspeakers are a real concentrate of technology and know-how. Versatile, with extensive connectivity,...
