TRIANGLE BOREA BR03 CONNECT Active Bookshelf Speakers Black
Triangle Borea BR03 Connect active bookshelf speakers provide a complete, versatile stereo sound system. They incorporate a high-performance amplifier, making it easy to add sound to rooms from 15m² to 40m².
By buying this product you get 64 loyalty points
Reference : 18631
649,00 €tax incl.
540,83 € tax excl.
Shipping date: 24-04-2025.
Triangle Borea BR03 Connect Active Bookshelf Speakers Bluetooth 5.0 aptX HD 2x60W Black (Pair)
Enceintes Triangle Borea BR03 Connect
The BR03 Connect has been designed for versatile use, adapting perfectly to today's needs. With this in mind, they feature Bluetooth aptX HD reception for remote broadcasting, a phono input for connecting a turntable, an optical and HDMI (ARC/CEC) input for association with a TV, a USB-B input for use with a computer, and even a subwoofer output offering the possibility of associating a subwoofer (not supplied).
A true integrated HiFi system, the BR03 Connect features a Class D amplifier capable of delivering a comfortable 2x60W RMS power. Each speaker is equipped with an EFS fabric dome tweeter and a 16.5cm diameter bass-midrange driver. As a result, these compact bookshelf speakers are capable of developing a rich sound image, marked by powerful, controlled bass, smooth midrange and precise treble.
Triangle Borea BR03 Connect: Key features
Triangle Borea BR03 Connect: High-end design
Borea BR03 Connect loudspeakers are built from high-density wood and equipped with the latest generation of Triangle loudspeakers. All Borea loudspeakers benefit from the technological and acoustic innovations of the Esprit Ez series, including cabinetry and driver diaphragms.
EFS Tweeter:
The tweeter used in Borea range loudspeakers benefits from a new-generation system called EFS (Efficient Flow System). This is based on the combination of a 25mm silk dome renowned for its neutrality, and a phasing element specifically developed to homogenize high-frequency diffusion. This system drastically reduces the directivity factor, whatever your listening position in the room. The loudspeaker's membrane is placed inside a horn, limiting edge effects for clear, limpid high-frequency reproduction. The transducer is powered by a neodymium magnet motor, capable of generating high magnetic power in a compact package. It is combined with a heatsink to guarantee better power handling.
Bass-Medium in natural cellulose:
The speakers in the Borea range use a midrange driver with a 100% natural cellulose pulp cone, untreated. This avoids any coloration of the midrange frequencies, to reproduce voices realistically, while offering a characteristic grain of the finest effect. The diaphragm profile has been reworked to increase rigidity and improve frequency response.
DVAS system:
Following extensive research into ways of reducing internal cabinet vibrations, the Borea range of loudspeakers incorporates perforated internal panels made of MDF and EVA foam, to stiffen the transducer and cabinet assembly. This process reduces structural vibrations, while absorbing those generated by low frequencies.
This proprietary system, developed by Triangle and known as DVAS (Driver Vibration Absorption System), uses a high-density EVA foam gasket at the end of each internal bracing to ensure perfect contact between the driver and the bracing, thus greatly attenuating the vibrations generated by the driver and transferring only a small amount of vibration to the cabinet. When you listen to it, this DVAS system ensures great neutrality and clarity, without sound coloration.
Decoupling:
Each speaker in the Borea range has its own decoupling system. BR03 Connect speakers are supplied with rubber pads to protect the underside of your speakers, but also to limit the transmission of vibrations.
Magnetic cover:
All speakers in the Borea range benefit from a magnetic protective cover, revealing no screws or inserts.
Triangle Borea BR03 Connect: Bluetooth reception
Triangle Borea BR03 Connect: Wireless reception
Triangle Borea BR03 Connect speakers benefit from Bluetooth 5.0 reception, enabling you to stream your music remotely, from a smartphone or tablet for example. Support for aptX, aptX LL and aptX HD codecs enables high-quality wireless transmission, with source sampling rates of up to 24bit 48kHz.
Triangle Borea BR03 Connect: Don't put your vinyl in the closet
The BR03 Connect are also designed to let you enjoy your vinyl collection. These speakers feature an MM phono preamplifier and a phono input, so you can connect a turntable directly without the need for additional equipment.
Triangle Borea BR03 Connect with phono turntable
Triangle Borea BR03 Connect with TV
Triangle Borea BR03 Connect: The open door to home cinema
Borea speakers are equally at home as an addition to an audio-video system, offering excellent sound immersion. A TV set can be connected directly via the optical, coaxial or HDMI (ARC/CEC) inputs. The BR03 Connect can also be used in conjunction with a subwoofer, such as the Triangle Tales 340 (sold separately), for a more powerful low-frequency response.
Triangle Borea BR03 Connect: Attention to detail
Here, every detail has been refined and optimized for the most convincing HiFi experience possible, both in terms of design and performance. The speakers are supplied with a radio remote control for simple remote control. A discreet LED in one corner of the speaker indicates the active source with a simple color code.
Triangle Borea BR03 Connect: Design and magnetic front cover
Product typeActive speakers
Speaker typeBass Reflex
Number of drivers2
DriversTweeter Ø25mm
Bass-Medium Ø16cm
Sensitivity90dB/W/m
Amplification typeClass D
Power2x60W RMS
Frequency response47Hz - 22kHz
Min/max impedance4.2Ω / 8Ω
InputsBluetooth 5.0
1x Jack 3.5mm
1x Optical Toslink
1x Coaxial
1x Steroe RCA (line / phono MM)
1x HDMI (ARC/CEC)
Output1x Subwoofer output (RCA)
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Supported audio formatsMP3, WMA, APE, FLAC, WAV, Apple Lossless
Dimensions (L x H x P)206 x 360 x 314mm
Weight (pair)16.7kg
Package2x Borea BR03 Connect
1x Remote control
1x Power cable
1x Speaker cable 3m
Impedance (Ω)4
Impedance (Ω)8
Efficiency / Sensitivity (dB)90.0
Lowest frequency (Hz)47
Highest frequency (Hz)22000
Power (W)60.0
Number of ways2
Speaker typeActive
Speaker form factorBookshelf speaker
TRIANGLE BOREA BR03 CONNECT Active Bookshelf Speakers Bluetooth 5.0 aptX HD 2x60W Black (Pair)
Triangle Borea BR03 Connect active bookshelf speakers provide a complete, versatile stereo sound system. They incorporate a high-performance...
