Active Speakers Bluetooth aptX 2x50W 89dB 56Hz-22kHz Light oak (Pair)
Triangle's Active Series speakers are the next generation of ultra-connected HiFi speakers. You can listen to your music from your phone, tablet or turntable and enjoy immersive and dynamic stereo sound. A true all-in-one HiFi system, the LN01A integrates a 2x50W Class D amplifier allowing you to fully enjoy your music.
With the LN01A, Triangle has thought of vinyl lovers. No need to add a dedicated preamplifier to listen to your favorite records, your turntable can be directly connected to the speakers thanks to the integrated phono input.
With these speakers, the emphasis is on connectivity and ease of use. They are indeed equipped with a Bluetooth 4.0 AD2P receiver compatible with the high-definition transmission codec aptX, allowing to read audio streams up to 16bit 44.1kHz. The use is thus very easy while preserving a remarkable audio quality.
With their numerous inputs, the LN01A can be integrated into a home cinema configuration. A subwoofer output even allows the addition of a possible subwoofer (not supplied) for even deeper bass.
Product type | Active speakers |
Speaker type | Bass Reflex |
Number of drivers | 2 |
Drivers | Tweeter 25mm Woofer 13cm |
Recommended room size | 15 to 30m². |
Sensitivity | 89dB/W/m |
power handling | 2x50W |
Bandwidth (+3dB) | 56Hz - 22kHz |
Min/Max nominal impedance | 4.5 / 8Ω |
Connectivity | Bluetooth 1x Stereo RCA 1x AUX Jack 3.5mm 1x Optical 1x Coaxial 1x Subwoofer output |
Supported Bluetooth codecs | aptX |
Dimensions | 165 x 235 x 291mm |
Weight | 9.5kg |
Color | Light oak |
Quantity | Pair |
Color | Light Oak |
Impedance (Ω) | 8 |
Impedance (Ω) | 4 |
Efficiency / Sensitivity (dB) | 89.0 |
Lowest frequency (Hz) | 56 |
Highest frequency (Hz) | 22000 |
Power (W) | 50.0 |
Number of ways | 2 |
Speaker type | Active |
Speaker form factor | Bookshelf speaker |
