Active Subwoofer Class D 200W 30-120Hz Black
The Triangle Tales 340 active subwoofer is versatile and can be integrated into a HiFi or Home Theater installation. This one is equipped with a 25cm diameter loudspeaker with a long travel and a Class D amplifier allowing it to deliver a power of 200W RMS (350W max). It will enable you to bring to a stereo system a beautiful base in the bass as well as a great dynamism. The Tales is a complete model, integrating an automatic switch on and off as well as an adjustment of the crossover frequencies allowing an optimal adjustment of the subwoofer within your system.
Product type | Active subwoofer |
Load type | Bass Reflex |
Loudspeaker diameter | Ø25cm |
Frequency response (+3dB) | 30-120Hz |
Amplification type | Class D |
Power | 200W RMS |
Dimensions | 342 x 383 x 357mm |
Weight | 8.85kg |
Color | Black |
Color | Black |
Lowest frequency (Hz) | 30 |
Highest frequency (Hz) | 120 |
Power (W) | 200.0 |
Speaker type | Active |
