YAMAHA NS-SW050 Active Subwoofer
The Yamaha NS-SW050 active subwoofer is a bass-reflex model equipped with a 50W amplifier stage and a 20cm subwoofer. Its side-mounted Twisted Flare Port is optimized for perfect airflow and punchy bass. The subwoofer also benefits from Yamaha's proprietary Advanced YST II (Yamaha Active Servo Technology II) for excellent driver control and linear response from 28Hz to 200Hz.
Reference : 18747
249,00 €tax incl.
207,50 € tax excl.
Yamaha NS-SW050Active Subwoofer 50W 28Hz-200Hz Ø20cm
Yamaha NS-SW050: Main view
The Yamaha NS-SW050 active subwoofer is a bass-reflex model equipped with a 50W amplifier stage and a 20cm subwoofer. Its side-mounted Twisted Flare Port is optimized for perfect airflow and punchy bass. The subwoofer also benefits from Yamaha's proprietary Advanced YST II (Yamaha Active Servo Technology II) for excellent driver control and linear response from 28Hz to 200Hz. This model is therefore ideal for integration into a small or medium-sized HiFi or home-cinema system, to enjoy deeper bass and greater immersion in your music or films.
In terms of connectivity, the Yamaha NS-SW050 subwoofer is equipped with an LFE input (mono RCA), so it can be combined with a system featuring a preamplified subwoofer or LFE output. The rear panel also features a volume control knob.
Product typeActive subwoofer
Load typeBass-Reflex
Driver diameterØ20cm (8")
Frequency response28Hz-200Hz
Vent positionLateral
PowerRMS : 50W (100Hz, 5Ωn 10% THD)
Max :100W (5Ω)
Volume control
Connectivity1x LFE (RCA) input
Dimensions (W x D x H)291 x 341 x 292mm
Weight8.5kg
ColorNoir
Lowest frequency (Hz)28
Highest frequency (Hz)200
Power (W)50.0
Speaker typeActive
YAMAHA NS-SW050 Active Subwoofer 50W 28-200Hz Ø20cm
The Yamaha NS-SW050 active subwoofer is a bass-reflex model equipped with a 50W amplifier stage and a 20cm subwoofer. Its side-mounted Twisted...
