CANARE RJ-RU High performance RCA inlet 75 Ohm à souder
4.0 / 5
Reference : 11275
11,90 €tax incl.
9,92 € tax excl.
This RCA 75 Ohm base developed in Japan by CANARE ensures a high quality signal.
Its notoriety is no longer to be done and the connectors of the firm, initially intended for the professional market, did not take long to break into the Hi-Fi market.
The External RCA Female Socket section allows you to connect a male RCA connector. the internal wiring allows soldering on printed circuit boards in an appliance./ P>
Features:/ Strong>
  • Female RCA socket
  • Material: metal
  • Impedance: 75 Ohm
  • Welding.
  • Dimensions: 30x25x24mm
  • Diameter of drilling: 20mm
  • Distance between centers: 23mm
  • Weight: 18g
Max cable diameter (mm)N/A
ConnecticFemale
Max panel thickness (mm)N/A
2 reviews
Alain D
Très bonne fabrication excellent contact.
This review has been posted for CANARE RJ-RU High performance RCA inlet 75 Ohm à souder
CANARE
Très bonne qualité de fabrication facile à souder
