CANARE RJ-RUD High performance RCA inlet 75 Ohm à souder
Reference : 11276
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 23-04-2025.
This RCA 75 Ohm base developed in Japan by CANARE ensures a high quality signal.
Its notoriety is no longer to be done and the connectors of the firm, initially intended for the professional market, did not take long to break into the Hi-Fi market.
The External RCA Female Socket section allows you to connect a male RCA connector. The chassis corresponds to the D design of the Neutrik brand.
Features:/ Strong>
  • Female RCA socket
  • Material: metal
  • Impedance: 75 Ohm
  • Welding
  • Dimensions: 31x26x33 mm
  • Diameter of drilling: 21.4mm
  • Internal diameter: 23mm
  • Spacing: 19mm
  • Weight: 18g
Max cable diameter (mm)N/A
ConnecticFemale
Max panel thickness (mm)N/A
