Die Kompatibilität zu den JAB2 und JAB3 ist gegeben, mehr wollte ich nicht. Es ist aber ein eigenständiges Ladeboard und kann nicht kaskadiert werden.
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 18650 and has 3 slots and a complete protection system. Very compact, it can power small systems or become a real portable battery. With its MPPT regulators, this module can therefore also operate as a charger, once powered by a voltage of 15-24V. The module has 4-level indicators to display the battery charge level.
Battery BMS Power Supply / Charger Module Lithium 18650 with Protections
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 18650 and has 3 slots and a complete protection system. The module provides an output voltage of 12V DC. Very compact, it can power small systems or become a real portable battery. With its MPPT regulators, this module can therefore also operate as a charger, once powered by a voltage of 15-24V. The module has 4-level indicators to display the battery charge level.
The integrated protection system operates constantly and monitors each cell voltage, load and discharge current, and environmental temperature to provide protection against overloads, overcurrents and excessive temperatures.
Li-Ion batteries are sold separately. We recommend these batteries LG Electronics NR18650F1L of very good quality.
In this video, the Wondom brand presents the product as well as its features and protections but also its possible applications. In the middle of the video, a series of tests allows to highlight the values measured on this charger.
Output voltage | 12V DC |
Supported batteries | Li-Ion 18650 |
Protections | Overcharge / Over-discharge Overcurrent Over temperatures |
Solar charging compatibility | Yes |
Number of battery slot | 3 |
Charging indicators | Yes |
Power supply | 15-24V DC via Jack DC 5.5/2.1mm or 2 poles connector |
Max discharge current | 10A |
Max charge current | 1.5A |
Package | Power supply module / 1x Cable XH 4 PIN |
Electrical characteristics | |||||
Parameter | Conditions | Min. | Typ. | Max. | Unit |
Charging voltage | - | 15 | 19 | 24 | VDC |
Standby power | V1=V2=V3=2V | - | - | 10 | uA |
Max discharge current | - | - | - | 10 | A |
Charge current | - | - | 1.5 | - | A |
Overcharge detection voltage | Single cell | - | 4.235 | - | V |
Overcharge release voltage | Single cell | - | 4.18 | - | V |
Overdischarge detection voltage | Single cell | - | 2.8 | - | V |
Overdischarge release voltage | Single cell | - | 3 | - | V |
Operating temperature | - | - | 20 | 50 | °C |
Min and max temperature | - | -20 | 20 | 105 | °C |
Input |
Output |
Output voltage (V) |
Output current (A) |
Input voltage (V) |
Power Supply |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Andreas L.
