This elegant 100% Aluminium DIY box is ideal for integrating a preamplifier, a class D amplifier (volume knob on the front panel) or any other Hifi video audio system such as an input selector or a phono stage.
The pre-drilled holes for the standard size speaker terminals and RCA sockets simplify the assembly for a professional quality finish.
The robust design ensures efficient installation and operation with a high quality Hifi finish.
Internal Dimensions :
External Dimensions :
Rear side drilling dimensions :
RCA diameter: 10mm
Diameter Speaker Terminals: 13mm
Dimensions of front panel holes :
Drilling for RK27 compatible potentionmeter: 6mm diameter
Recessed part for aluminium button: 30mm diameter
Case sold for assembly.
Features:
This box is supplied with a 30mm volume knob compatible with RK27 potentiometer, a power ON/OFF button, full set of screws and bolts, 4 non-slip feet.
Recommended connections :
Borniers Hauts parleurs plaquées Or Elecaudio BP-202 fiche 7629
Embases RCA Isolées PTFE Elecaudio ER-105 fiche 7413
