C'est un très beau boitier esthétiquement et mécaniquement parlant.
Dommage que deux équerres internes ne soient pas à la bonne dimension. Heureusement, elle ne sont pas absolument nécessaires et une adaptation peut être envisagée.
This stylish DIY 100% Aluminum case with exceptional dimensions is equipped with high quality heat sinks as well as ventilated covers.
It is an ideal case to integrate a large and powerful high fidelity amplifier or any other audio editing.
It is equipped with a front hole for receiving the On / Off and Volume Aluminum buttons, machining on the rear panel for the IEC socket for power supply and drilling for the RCA sockets and terminal blocks.
Its robust and sophisticated design ensures an efficient assembly and use with a professional finish around an innovative design.
Note: Some housings are machined directly into the ground. Thus, certain angles and / or edges can be sharp.
Care should be taken when handling this type of enclosure.
Dimensions Internal:
External Dimensions:
Box sold to assemble.
Characteristics :
Color | Black |
Color | Silver |
Material | Aluminium |
Internal width | 330 |
Internal depth | 300 |
Internal height | 112 |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Didier a.
