100% Aluminium Drilled DIY Box / Case for amplifier 430x311x151mm
By buying this product you get 30 loyalty points
Reference : 11323
309,00 €tax incl.
257,50 € tax excl.
This elegant DIY 100% Aluminum case is ideal for integrating a high power amplifier, or any other audio editing of your choice. A push button slot (provided) is provided on the front panel, allowing easy and easy access to power-up.
Holes are already made on the back of the case, allowing you to place your various connectors directly: Terminal blocksLoud speakerand RCA.
Its robust design ensures an efficient assembly and use with a professional finish. Its aesthetics and design make it a top-of-the-range housing and will fit perfectly with your HiFi system.
This DIY case is sold to climb .
Internal dimensions:
  • Working width: 331 mm
  • Working depth: 301 mm
  • Working height: 142 mm
External dimensions:
  • Width: 430 mm
  • Depth: 311 mm
  • Height: 151 mm
Hole dimensions:
  • HP Terminal Blocks: Diameter Ø 12mm
  • RCA: Diameter Ø 11mm
Features:/ Strong>
  • Solid Brushed Aluminum CNC (Numerical Control Machine)
  • Front: 8mm
  • Rear face: 3mm
  • Sides: 10mm
  • Width of fins: 39mm
  • Weight: 7.96kg
  • Supplied with screws, IEC socket with fuse holder (fuse not supplied), push button, and 4 non-slip feet.
MaterialMetal
Internal width331
Internal depth301
Internal height142
