Aluminium Case 220x191x52mm Silver Front Panel
This 100% Aluminium housing will allow you to integrate a DIY design such as an amplifier or DAC. It is delivered with an Aluminium button, an ON/OFF switch and an IEC base. The rear panel has holes for the IEC base plate and for audio connectors (RCA, Coaxial...).
Reference : 13649
37,90 €tax incl.
31,58 € tax excl.
Aluminium Case
Aluminium Case 220 x 191 x 52mm Silver Front Panel
Boîtier Aluminium 220 x 191 x 52mm Façade Argent
The housing is delivered disassembled with all the screws and bolts required for its assembly.
Product typeCase
MaterialBrushed Aluminium
External dimensions220 x 191 x 52mm
Internal dimensions200 x 182 x 48mm
ColorsFront panel : Silver
Rest of the chassis : Black
Panels thicknessFront panel : 6mm
Back panel : 2mm
Side panels : 6mm
Top / Bottom panels : 2mm
Back panel round cutout diameter10.5mm
IEC Cutout dimenions28 x 31mm
IEC fixation holes spacing36mm
Weight1.2kg
Package1x Case to mount
1x Button
1x ON/OFF switch
1x IEC plug
Screws
ColorSilver
MaterialAluminium
Internal width200
Internal depth182
Internal height48
beau boitier.
A ce prix, très bon boitier de bonne facture.
This review has been posted for Aluminium Case 220x191x52mm Silver Front Panel
This 100% Aluminium housing will allow you to integrate a DIY design such as an amplifier or DAC. It is delivered with an Aluminium button, an...
