Aluminium Case with Heatsink 311x260x120mm Silver Front Panel
This 100% Aluminium DIY box equipped with two cooling radiators / lateral heat sinks will allow you to integrate an amplifier or any other audio mounting.
Reference : 13647
119,00 €tax incl.
99,17 € tax excl.
Aluminium Case
Aluminium Case with Heatsink 311x 260 x 120mm Silver Front Panel
Boitier Aluminium avec Dissipateur thermique 311x 260 x 120mm Façade Argent
This 100% Aluminium DIY box equipped with two cooling radiators / lateral heat sinks will allow you to integrate an amplifier or any other audio mounting. Its design allows it to benefit from very good heat dissipation, thus allowing you to integrate components that release heat. Its design ensures professional assembly and finishing.
Specfications
Product typeCase
MaterialAnodized brushed Aluminium
External dimensions (WxDxH)260 x 311 x 120mm
Internal dimensions (WxDxH)160 x 300 x 111mm
ColorsFront panel : Silver
Rest of the chassis : Black
Heatsink dimensions40 x 300 x 114mm
Panels thicknessFront panel : 8mm
Back panel : 2.8mm
Side panels : 9.5mm
Top / Bottom panels: 3mm
Weight4.96kg
ColorSilver
MaterialAluminium
Internal width160
Internal depth300
Internal height111
This 100% Aluminium DIY box equipped with two cooling radiators / lateral heat sinks will allow you to integrate an amplifier or any other audio...
