Aluminium Case with Heatsink 430x311x70mm Silver Front Panel
This 100% Aluminium DIY box equipped with two cooling radiators / lateral heat sinks will allow you to integrate an amplifier or any other audio mounting. Its design allows it to benefit from very good heat dissipation, thus allowing you to integrate components that release heat.
Reference : 13648
149,00 €tax incl.
124,17 € tax excl.
Aluminium Case
Aluminium Case with Heatsink 430 x 311 x 70mm Silver Front Panel
Boitier Aluminium avec Dissipateur thermique 430 x 311 x 70mm Façade Argent
This 100% Aluminium DIY box equipped with two cooling radiators / lateral heat sinks will allow you to integrate an amplifier or any other audio mounting. Its design allows it to benefit from very good heat dissipation, thus allowing you to integrate components that release heat. In addition, it ensures professional assembly and finishing.
Product typeCase
MaterialAnodized brushed Aluminium
External dimensions430 x 311 x 70mm
Internal dimensions330 x 300 x 64mm
ColorsFront panel : Silver
Rest of the chassis : Black
Heatsink dimensions40 x 300 x 66mm
Panels thicknessFront panel: 8mm
Back panel: 3mm
Side panels: 9.3mm
Top / Bottom panels: 3mm
Back panel round cutout diameter10.5mm
IEC cutout dimensions28 x 20mm
IEC fixation holes spacing40mm
Weight4.36kg
Package1x Boîtier
1x IEC Socket
4x Anti-slip feet
ColorSilver
MaterialAluminium
Internal width330
Internal depth300
Internal height64
This 100% Aluminium DIY box equipped with two cooling radiators / lateral heat sinks will allow you to integrate an amplifier or any other audio...
