Aluminium chassis for I-Sabre V2 / V3 DAC & Raspberry Pi 3 / Pi 2 B for OLED
This 100% Aluminum case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 or Pi 3 Model B and the Audiophonics DAC I-Sbre V2 or V3 ES9023.
Reference : 11138
49,90 €tax incl.
41,58 € tax excl.
It has all the inputs / outputs necessary for its connection, its power (Jack DC 5.5 / 2.5mm), drilling for the POWER button, an HDMI offset hole, a micro SD card slot, a drilling dedicated to a infrared receiver, and an OLED display slot.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment.
Thanks to this particularly robust and elegant case, you have a high-performance audio solution that has achieved excellent value for money.
Warning This product is not compatible by default (welds to be made) with the I-Sabre V1 (9341 and 10296)
Characteristics :
  • Housing 100% Aluminum
  • Black anodized
  • Dimensions: 160x140x50mm
  • Display dimensions: 65x16mm (standard HD44780 16x2)
  • Display distance: 75x31mm
  • Weight: 0.8kg
  • Infrared Receiver Location
  • SD card slot
  • Port RJ45 x1
  • USB-A x4 port
  • HDMI port x1 (27mm center distance)
  • Analog stereo output RCA x1 (Ø 12mm)
  • Input Jack DC 5.5 / 2.5mm (Ø 9mm)
  • Switch position (Ø 19mm)
  • Screws provided (uniquthe case of the case, the necessary to fix the screen is not provided).
  • Exclusive design
  • Raspberry Pi 2 model B / Raspberry Pi 3 model B / Audiophonics DAC I-Sabre V2 ES9023 / Audiophonics DAC I-Sabre V3 ES9023 .
[Img-18230-left-thickbox_default]
[Img-18231-left-thickbox_default]
[Img-18232-left-thickbox_default]
[Img-18233-left-thickbox_default]
[Img-18234-left-thickbox_default]
MaterialMetal
This 100% Aluminum case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 or Pi 3 Model B and the Audiophonics DAC I-Sbre V2 or V3...
