Aluminium chassis for I-Sabre V2 / V3 DAC & Raspberry Pi 3 / Pi 2 B
Reference : 10883
49,90 €tax incl.
41,58 € tax excl.
This 100% Aluminum case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 / Pi 3 Model B & Audiophonics DAC I-Sabre V2 / V3 ES9023.
It has all the inputs / outputs necessary for its connector, its power (Jack DC 5.5 / 2.5mm), as well as an HDMI offset.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment.
Thanks to this particularly elegant and discreet case, you have a high-performance audio solution at an excellent value for money.
Characteristics :
  • Housing 100% Aluminum
  • Black anodized
  • Dimensions: 160x140x50mm
  • Weight: 0.8kg
  • Port RJ45 x1
  • USB-A x4 port
  • HDMI port x1 (27mm center distance)
  • Analog stereo output RCA x1 (Ø 12mm)
  • Input Jack DC 5.5 / 2.5mm (Ø 9mm)
  • Switch position (Ø 19mm)
  • Screws supplied
  • Exclusive design
  • Case delivered bare without Raspberry Pi 2 Model B , Raspberry Pi 3 Model B , and <a href = "https://www.audiophonics.fr/fr/kits-modules-diy-dac/audiophonics-i-sabre-dac-es9023-v2-tcxo-raspberry-pi-20-ab-i2s-p- 10176.html "target =" _ blank "> Audiophonics DAC I-Sabre V2 ES9023, Audiophonics DAC I-Sabre V3 ES9023 .
The housing drilling allows the AUDIOPHONICS I-Sabre DAC V2 line jack to be used for the 3.5mm Jack line output </ a> or the AUDIOPHONICS I-Sabre DAC V3 . The power supply is then via a USB-A port.
Screws supplied:
2x Nut HU Steel Zinc Plated M2x1.45mm
2x Screw TFHC countersunk head Carbon steel DIN7991 M2x16mm
4x Screw TFHC countersunk head Steel M2.5x5mm
4x Spacer M2.5 Brass screw thread 5mm
MaterialMetal
Magnifique Boîtier
Boitier avec de belles finitions. Il trouvera facilement une place dans une installation audio / video.
Merci Audiophonics !
This review has been posted for Aluminium chassis for I-Sabre V2 / V3 DAC & Raspberry Pi 3 / Pi 2 B
