sur la face arriere decalage pour l'entree usb-c et prises rca,de qqs mms,il a fallu que j'agrandisse les trous.
Face avant le tou prevu pour la petite lampe de fctionnement de l'appareil n'est pas en face de la dite loupiote.
CAUTION : this is the housing only. Tone Board DAC is Sold separately.
This alumunium housing is designed to accommodate your card ToneBoard Khadas stand-alone (one card). It provides an independent and functional finished DAC from the excellent DAC in Khadas. Whether you are curious about the entusiasthm met by Khadas DIY DAC in audiophiles circles or you are already convinced and want a quick integration in a more complex audio system, this housing allow a easy mounting for an immediate use.
The openings provide quick access and secure all connectors. thus we end up on the same frontage digital input, analog outputs on RCA, the power supply / input on USB C.
Entirely made of aluminum, the case protects your Tone Board card against mechanical shock and most electromagnetic interference.
Once mounted, the set offers very advantageous dimensions: 102mm wide Pourr 65mm long with 30mm height.
The VIM Edition version of the Tone Board is not compatible with this box.
Design and conception by Audiophonics.
Type | Housing |
Compatibility | Tone Board (Generic) - Khadas |
Material | 100% Aluminum |
Dimensions | 65 x 102 x 30mm |
Weight | 105g (body only + screw + washers) |
Package Contents | |
lower plate | x1 |
top plate | x1 |
front plate | x1 |
backplate | x1 |
Mounting screws | x8 |
washers | x1 |
Use screws, nuts and spacers provided with the Tone Board for mounting the PCB |
Average votes 4.3 / 5 20 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Patrick G.
Pascal V.
Igors K.
Pete K.
Serdar C.
