Aluminum Casing for Toroidal Transformers 160x140x75mm SIlver
This aluminum cover/enclosure is designed to allow you to cover your transformers in a professional and elegant way. It also allows you to isolate a transformer from sensitive circuits to limit the impact of interference on the signal.
Reference : 17807
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 16-04-2025.
Aluminium casing
Aluminum Casing for Toroidal Transformers 160x140x75mm Silver
Boîtier Capot pour Transformateur Torique Aluminium 160x140x75mm Argent
This aluminium housing is not a full casing, it does not include the bottom plate. Screws are not supplied.
Product typeTransformer case / cover
MaterialBrushed aluminum
ColorSilver
Dimensions160*140*75mm
Internal dimensions138*131*70mm
Side panels thickness4.5mm
Top side thickness5mm
Screw threadM4
Thread spacing143*123*80mm
Weight850g
ColorSilver
MaterialAluminium
Internal width138
Internal depth131
Internal height70
This aluminum cover/enclosure is designed to allow you to cover your transformers in a professional and elegant way. It also allows you to isolate...
