Aluminum Chassis for Raspberry Pi 3 / ST4000 DAC Network audio player
Reference : 12179
39,00 €tax incl.
32,50 € tax excl.
Case for Pi3 / DAC ST4000
Elegant aluminum case
This new version of the 100% Aluminum case has been designed to accommodate the duo Raspberry Pi and the DAC ST 4000 Es9018K2M with HDMI offset.
Here is the DAC and compatible Raspberry Pi3 button with this case:
- ST 4000 ES9018K2M
- Switch black anodized circle bright white
This case to be assembled contains all the screen printing, the screws allowing an easy and fast assembly of any DIY project including Un Pi 3 and a DAC ST4000. It has been designed with the aim of to have the efficiency of your Raspberry Pi 3 in a high quality Audio environment. Thanks to this sleek and discreet case, you have a high-performance audio solution at an excellent value for money.
An assembled version of this case with Pi3 and DAC ST4000 exists here under the reference:
AUDIOPHONICS RaspDAC LTE 4000 Pi3 ES9018K2M
This kit is supplied without any button or accessories other than the screws. (see accessories).
Specs
HousingAluminum
MarkingMarking & Connectors
Color hullBlack Anodized
Color frontBlack
Dimensions100x167x50
Weight446g
Hole for HDMIx1
Slot Micro SDx1
RJ45x1
USB-Ax4
Stereo Analog outputØ12mm
Input Jack DC 5.5/2.5mmØ9mm
Front switchØ19mm
Screws providedYes
MaterialMetal
