Excellent quality. It's small but the end result, if you choose things that fit inside, is incredible!
100% Aluminium 147 x 105 x 42mm Black
This case has a black brushed aluminium body and a silver front panel for a sober and elegant look. This material gives this part a great robustness while allowing to reject electromagnetic disturbances likely to alter the various processes intervening in the restitution of the sound. Moreover, equipped with two large heat sinks on its sides, the case efficiently evacuates the heat released by your electronic components.
The rear panel is also pre-drilled for the integration of an IEC socket (supplied) and RCA connectors or terminal blocks (sold separately).
Case supplied disassembled.
Product type | Case |
Material | Aluminium |
External dimensions | Width: 260mm Depth: 167mm Height: 70mm |
Internal dimensions | Width: 180mm Depth: 155mm Height: 64mm |
Panel thickness | Front panel : 8mm Rear panel : 3mm Top and bottom panels : 3mm |
Holes | 1x hole for IEC socket (included) 6x round holes for RCA or speaker terminals connectors (sold separately) |
Weight | 1980g |
Colors | Front panel: Silver Other parts: Black |
Package | Case Screws IEC Connector Non-slip feet |
Average votes 4.8 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Nikolaos R.
Gilles G.
Melvin L.
Paulin A.
