DIY 100% Aluminum Chassis Black 50x40x60mm
This black aluminum chassis is ideal for a wide range of DIY projects. Its relatively compact dimensions allow you to build devices such as Bluetooth receivers, headphone amplifiers, small DACs, power supplies, buffers and more.
Reference : 19107
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 16-04-2025.
DIY Chassis 100% Aluminum Black 50x40x60mm
Photo du boîtier aluminium
This chassis has no pre-drilling, except for the mounting screws on the front and rear panels.
Dimensions du boîtier aluminium
Product typeDIY chassis
Material100% aluminum
External dimensions with panels50 (width) x 40 (height) x 63 (depth) mm
Internal dimensions43 (insert 46 - width) x 35 (insert 29 - height) x 60 (depth) mm
Panels thickness1.5mm
Screws included
Weight80g
Package1x DIY Chassis
MaterialAluminium
Internal width43
Internal depth60
Internal height35
This black aluminum chassis is ideal for a wide range of DIY projects. Its relatively compact dimensions allow you to build devices such as...
