DIY Amplifier Case Aluminum 260x170x70mm Black / Silver
This brushed aluminum case with silver front is ideal for integrating an amplifier or any other audio setup. With a professional quality design, this case is robust and durable, and will effectively protect your components.
Reference : 15067
34,90 €tax incl.
29,08 € tax excl.
DIY CAse
100% Aluminum 260 x 170 x 70mm
Boîtier DIY 100% Aluminium 291 x 172 x 60mm
This brushed aluminum case with silver front is ideal for integrating an amplifier or any other audio setup. With a professional quality design, this case is robust and durable, and will effectively protect your components. The case is pre-drilled: there is a space on the back panel to fix an IEC socket and 4 holes for RCA. The front panel allows the installation of a push button as well as a rotary switch.
Product typeDIY Case
MaterialBrushed Aluminum
External dimensions260 x 170 x 70mm
Internal dimensions250 x 153 x 59mm
Panels thicknessFront panel: 8mm
Rear panel: 3mm
Others panels: 4.7mm
DrillingsRear panel: 4x RCA Ø11mm
1x IEC 27.8 x 32mm
Front panel: 1x Ø13.5mm
1x Ø7mm
ColorFront panel: Silver
Others panels: Black
ColorSilver
MaterialAluminium
Internal width153
Internal depth250
Internal height59
This brushed aluminum case with silver front is ideal for integrating an amplifier or any other audio setup. With a professional quality design,...
