DIY Box 100% Aluminium 320x240x90mm Silver
Reference : 9297
75,00 €tax incl.
62,50 € tax excl.
Housing DIY 100% Aluminum rounded corners 320x240x90mm
This DIY 100% Aluminum case with rounded corners with a 35mm radius is ideal for integrating a DAC, preamplifier, amplifier or other audio editing.
Its robust design ensures an efficient assembly and use with a professional finish./ P>
Internal Dimensions:
  • Working width: 230mm
  • Available Depth: 307mm
  • Available height: 80mm
  • Predrilled IEC : 32mm x 27mm / Spacings 33mm
External Dimensions:
  • Width: 240mm
  • External Depth: 320mm
  • Height: 90mm
Box sold to assemble.
Specifications:
  • Solid Brushed Aluminum
  • Façade: 8 mm
  • Faces: 4mm
  • Weight: 2.6kg
  • Supplied with screws and IEC plug
Precautions for use: Special attention is required to the mounting, the manual adjustment and the finishes concerning the cover of this case.
ColorSilver
MaterialAluminium
Internal width230
Internal depth307
Internal height80
2 reviews
muy bonita
da pena tener que taladrar esta belleza,merci
This review has been posted for DIY Box 100% Aluminium 320x240x90mm Silver
Boitier alu
Vraiment un très beau boitier!
Façade de 8 mm ,entourage de 5mm et couvercles inf et sup d'au moins 3 mm tout ça en alu !!!!.
Encore +jolie (en vrai) que sur le visuel!
Mercie J.... Euh non Audiopnonics !!!!
