DIY Box / Case 100% Aluminium 260x311x90mm Silver Pannel
This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional quality finish. This box comes with all the necessary hardware, the IEC socket and 4 anti slip feet.
Reference : 12368
75,00 €tax incl.
62,50 € tax excl.
This beautifully made 100% Aluminum DIY case is perfect for designing High-End DAC or class D amplifiers.
Its original design ensures a professional fit and finish. It is also particularly suitable for the design of preamplifiers and audiophile power supplies.
internal Dimensions
Useful width220mm
Useful Depth295mm
Height :77mm
external Dimensions
Width :260mm
Depth :311mm
Height :90mm
technical features
Front anodized aluminium thickness :8mm
Rear facade thickness3mm
Weight :2.52Kg
Deliver with :Visseries, embase IEC, avec porte fusible et 4 pieds anti dérapants.
MaterialMetal
Internal width220
Internal depth295
Internal height77
2 reviews
Dragoslav
The box is excellent, without any complaints, the device you make will look great.
Thanks Audiophonics
This review has been posted for DIY Box / Case 100% Aluminium 260x311x90mm Silver Pannel
bon rapport qualité prix
Bonjour,
pas trop mal fini, certains trous sont à la limite du bord mais ne gênent en rien pour visser. tout rentre parfaitement les filetages sont bien fait, aucun soucis.
This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional...
