DIY Box / Case Integrated Amplifier 100% Aluminium 361x274x85mm
Reference : 10862
149,00 €tax incl.
124,17 € tax excl.
Boîtier DIY
Pour amplificateur intégré, 100% Aluminium, 361 x 274 x 85mm
Boîtier DIY amplificateur intégré 100% Aluminium 361 x 274 x 85mm
This 100% Aluminium DIY case in a Solid State HiFi design is equipped with the most beautiful radiators. In addition, there are pre-drilled holes for the transistors on the heat sinks as well as holes for stereo speakers and 2 RCA cinch (not included).
A slot for a source selector and another for the volume (holes compatible with ALPS RK27 potentiometers) are also pre-drilled in the front panel.
So here is a ready-to-use aluminium chassis allowing to integrate a controller, a preamplifier or an amplifier for example. Its original design assures you a professional assembly and finish at a low price.
The housing is delivered to be assembled. It may require adjustments depending on the integration.
Transistor spacing
Product typeCase
Internal dimensionsWidth : 300mm
Depth : 256mm
Height : 74mm
External dimensionsWidth : 361mm
Depth : 274mm
Height : 85mm
MaterialSandblasted aluminium
Weight3.6kg
ColorSilver
Front panel holesVolume and selector: Ø7.96mm x2
Switch : 4 x 5.92mm
Rear panel holesRCA : Ø11mm x6
IEC : 27.84 x 30.85mm (IEC holes spacing: 37mm)
PackageCase
1x ON/OFF switch
4x Anti-slip feet 21 x 10.38mm
2x Buttons 23.15 x 38mm
4x Cruciform PH1 3.88 x 17.85mm
4x BTR type H3
15x BTR H2.5 3.69 x 7.86mm
7x Cruciform 10.27 x 3.84mm
4x Cruciform 8.2 x 2.82mm
4x Nuts 6.85 x 2.9mm
ColorSilver
MaterialAluminium
Internal width300
Internal depth256
Internal height74
Execellent product, absolutely satisfied!
Always a guess when you order a casing. This one is very satisfactory! All components fit perfectly. The case was assembled without any effort.
One tip: Add exact drawings, having all dimensions makes it easier to add or adapt stuff. The end result will be even more perfect ;) I , for example, need to modify the top 'lid' to fit 3 transformers and two large KT120 tubes. Replacing the top lid with another plate is easiest but I need accurate dimension to get a good result without the inaccuracy of measuring it myself.
 (3)
This review has been posted for DIY Box / Case Integrated Amplifier 100% Aluminium 361x274x85mm
