Housing DIY 100% Aluminum 271x240x120mm
This DIY 100% Aluminum case has a sleek design and features non-slip feet.
Designed to integrate an amplifier, it will nevertheless allow you to integrate any other audio editing.
Its particularly careful design ensures a professional fitting and finishing.
Box sold to assemble.
Dimensions Internal:
- Working width: 200mm.
- Depth of use: 260mm.
- Working height: 110mm.
External Dimensions:
- Width: 240mm.
- Depth: 271mm.
- Height: 110mm.
Front drilling holes:
- Drilling "power" button Ø 13.4mm.
- 21.4mm "power" mounting clamping distance
- Drilling button volume Ø 7.5mm "type ALPS RK27".
- 4x Ø4.4mm diameter for front mounting.
- Machining for the volume knob Ø 38.7mm, depth: 5mm.
Drill holes rear facade:
- Hole of hole taken IEC 27.8x31.9mm.
- 6x RCA drilling holes and loudspeakers Ø 11.4mm.
- 4x drilling holes fixing rear cover Ø 4.5mm.
Specifications:
- Solid Brushed Aluminum
- Pre Percé for RCA sockets
- 2x2 hp terminal outputs
- Thickness of the side panels (support + fins): 20mm
- Front: 8mm
- Rear face: 3mm
- Dimensions of the radiators: 260x110x7mm
- Weight: 3.8kg
- Supplied with screws, non-slip, knob for aluminum potentiometer (diameter 25mm flat axis), IEC base, switch On / Off.
