DIY Case 100% Aluminium 311x140x90mm
This elegant 100% Aluminium DIY case with silver front is ideal for integrating a DAC, preamplifier, amplifier or other audio editing. With its professional design quality, this case is robust and durable and will effectively protect your components.
Reference : 13669
39,90 €tax incl.
33,25 € tax excl.
Aluminium Case
Boîtier 100% Aluminium 138 x 311 x 90mm
The housing is delivered disassembled, with the screws allowing its assembly.
Product typeCase
MaterialBrushed Aluminium
Machining methodCNC
External dimensions (L x P x H)140 x 311 x 90mm
Internal dimensions (L x P x H)130 x 300 x 84mm
Panels thickness
  • Front panel: 8mm
  • Back panel: 3mm
  • Side panels : 4mm
  • Top / bottom panels: 3mm
Colors
  • Front panel: Silver
  • Rest of the case : Black
Weight1.5kg
ColorSilver
MaterialAluminium
Internal width130
Internal depth300
Internal height84
This elegant 100% Aluminium DIY case with silver front is ideal for integrating a DAC, preamplifier, amplifier or other audio editing. With its...
