Magnifique boitier, très, très massif.
Les 4 côtés font 8mm d'épaisseur, donc attention aux usinages.
Un potentiomètre normal, par exemple, ne peut pas être vissé le filetage est trop court.
Pour les bons bricoleurs, super qualité.
430 x 330 x 80mm
This large 100% Aluminium DIY box with rounded corners over a 35mm radius will allow you to integrate the components of an amplifier, pre-amplifier, DAC, or any other audio editing. Robust and aesthetically pleasing, it will protect the components from shock and dust, and allow you to simply integrate your DIY mounting into your audio system. Its quality design ensures easy assembly and a professional finish.
Product type | Case |
Material | Sandblasted massive Aluminium |
External dimensions |
Internal dimensions |
Panels thickness | 8mm |
Package | 1x Case to mount Screws |
Note: No terminal plug or connector is provided with the housing. You can buy some separately.
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Francis P.
