DIY Case with Screen Cutout Aluminum 166x291x60mm Silver Front Panel
This brushed aluminum DIY case lets you cover and protect your modules, such as an amplifier. The front and rear of the case have holes for easy integration of your components (connectors and screen).
Reference : 19282
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 16-04-2025.
Photo of assembled DIY case
This brushed aluminum DIY case lets you cover and protect your modules, such as an amplifier. The front and rear of the case have holes for easy integration of your components (connectors and screen). In addition, the case is supplied with various accessories: volume knob, ON/OFF button, IEC base switch, acrylic screen plate, rubber feet and screws.
DIY case package
Product typeDIY case
Max. external dimensions166x291x60mm
Max. internal dimensions158x280x48mm
Panel thicknessFront panel: 8mm
Rear panel: 3mm
Top / bottom panels: 2.5mm
Cutout diameter for RCAØ11mm
Screen cutout dimensions64.7 x 15.5mm
Screen mounting center distances93 x 30mm
ColorFront panel: silver
Rest of case: black
Volume knob: black
Package content1x Front panel
1x Rear panel
1x Top panel
1x Bottom panel
1x Volume knob
1x ON/OFF button
1x On/off switch
1x IEC base
4x Rubber feet
Screws
ColorSilver
MaterialAluminium
Internal width158
Internal depth280
Internal height48
This brushed  aluminum DIY case  lets you cover and protect your modules, such as an amplifier. The front and rear of the case...
