DIY Case with Screen Cutout Aluminium 172x250x60mm Silver Front Panel
This brushed Aluminium DIY box will allow you to cover and protect your modules, such as for example for an amplifier. The rear panel of the case has holes to facilitate the integration of your components.
Reference : 13632
49,90 €tax incl.
41,58 € tax excl.
DIY Case
DIY Case with Screen Cutout Aluminium Silver / Black
Boîtier DIY avec Découpe pour Afficheur Aluminium Argent / Noir
This brushed Aluminium DIY box will allow you to cover and protect your modules, such as for example for an amplifier. The rear panel of the case has holes to facilitate the integration of your components (connectors and display). In addition, the housing is supplied with various accessories: volume knob, ON/OFF knob, IEC base switch, acrylic plate for display, rubber feet and screws.
Product typeCase
MaterialBrushed Aluminium
Max external dimensions172 x 250 x 60mm
Internal dimensions158 x 240 x 48mm
Panels thicknessFront panel : 8mm
Back panel : 3mm
Top / Bottom panels : 2.5mm
Package1x Front panel
1x Back panel
1x Top panel
1x Bottom panel
1x Volume button
1x ON/OFF button
1x Switch
1x IEC Plug
1x Acrylic plate for screen
4x Rubber feet
Screws
ColorsFront panel : Silver
Rest of the case : Black
RCA Cutout diameter11mm
Screen window dimensions64.7 x 15.5mm
Screen fixation holes spacing93 x 30mm
ColorSilver
MaterialAluminium
Internal width158
Internal depth240
Internal height48
2 reviews
PGA2311 Case
Very good case, with modified display (OLED instead backlight LCD), very, very nice PREamp.
This review has been posted for DIY Case with Screen Cutout Aluminium 172x250x60mm Silver Front Panel
As described
Good quality, nice finish, all as described. Recommended
This brushed Aluminium DIY box will allow you to cover and protect your modules, such as for example for an amplifier. The rear panel of the case...
