DIY DAC / Phono Case 100% Aluminum 290x172x60mm
This brushed aluminum case with silver front is ideal for integrating a DAC, a phono preamplifier or any other audio setup. With a professional quality design, this case is robust and durable, and will effectively protect your components.
Reference : 15056
36,90 €tax incl.
30,75 € tax excl.
DIY CAse
100% Aluminum 290 x 172 x 60mm
Boîtier DIY 100% Aluminium 291 x 172 x 60mm
This brushed aluminum case with silver front is ideal for integrating a DAC, a phono preamplifier or any other audio setup. With a professional quality design, this case is robust and durable, and will effectively protect your components. The case is pre-drilled: there is a space on the rear panel to fix an IEC socket and 6 holes for RCA. The front panel allows the installation of a push button as well as a rotary switch.
The box is delivered with an IEC base, a push button, a rotary knob (potentiometer sold separately), rubber feet and screws.
Product typeDIY Case
MaterialBrushed Aluminum
External dimensions290 x 172 x 60mm
Internal dimensions280 x 152 x 48mm
Panels thicknessFront panel: 8mm
Rear panel: 3mm
Others panels: 4.7mm
DrillingsRear panel: 6x RCA Ø11mm
1x IEC 27.8 x 32mm
Front panel: 1x Ø10.8mm
1x Ø7mm
Supported samplingHDMI-CEC
HDR
DVD-Audio
DSD
Dolby True HD / DTS-HD Master Audio
3D
Canal réseau (100Mbit/s)
ARC / eARC
VRR
QMS
QFT
ALLM
DSC
ColorFront panel: Silver
Others panels: Black
ColorSilver
MaterialAluminium
Internal width152
Internal depth280
Internal height48
This brushed aluminum case with silver front is ideal for integrating a DAC, a phono preamplifier or any other audio setup. With a professional...
