LITE AUDIO A28D Case 410x100x330mm Black
This Lite Audio A28D box is ideal for designing a DIY audio system such as a power amplifier, preamplifier or DAC. Robust, with a 6mm thick front panel, the case will properly protect all components from impact and dust.
Reference : 13817
49,90 €tax incl.
41,58 € tax excl.
Lite Audio A28D
Housing 410x100x330mm Black
This Lite Audio A28D box is ideal for designing a DIY audio system such as a power amplifier, preamplifier or DAC. Robust, with a 6mm thick front panel, the case will properly protect all components from impact and dust. This front panel also includes a Power ON/OFF button. The rear face is pre-drilled, allowing to accommodate five stereo RCAs and a power supply base (supplied). The housing is also supplied with four feet.
Pre-drilled bottom for Lite Audio modules.
Product typeCase
MaterialFront panel : Aluminium
Other panels : anti-scratch paint
ColorFront panel : Black
Others parts of the case : Black
Dimensions (L x D x H)410 x 330 x 100mm
Front panel dimensions (L x H)430 x 100mm
Front panel thickness6mm
Weight4kg
Package1x Lite Audio A28D case
5x Stereo RCA
1x ON/OFF button and switch
1x Power connector
4x Feet
1x LED
ColorSilver
MaterialAluminium
Internal width410
Internal depth330
Internal height100
4 reviews
Behuizing
Mooi afgewerkt, prijs waard.
This review has been posted for LITE AUDIO A28D Case 410x100x330mm Black
LITE AUDIO A28D Boîtier 410x100x330mm Noir
Bonjour,
Rapport qualité/prix imbattable, bonne finition, solide et rigide.
Et en bonus, le boîtier est livré avec les prises RCA, la visserie, l’interrupteur, la diode Led, les pieds et la prise ICE.
Idéal pour du DIY.
Juan
very good.....
good service..
Excellent rapport qualité prix !
Bien que mon boîtier ne sois encore intégré dans mon petit projet, j'ai pu le monter sans problème particulier.
Dommage qu'une notice de montage, même succincte ne soit fournie (principalement pour le repérage des vis en fait).
Il faudra faire un peu attention car la qualité (et placement) des taraudages et des vis sont un peu aléatoires, sans que ce ne soit réellement gênant au final.
Pour le reste, je suis réellement très agréablement surpris par la qualité d'ensemble du boîtier.
Une fois assemblé, c'est parfaitement rigide, même pour accueillir une grosse alimentation.
La finition est très bonne et le boîtier présente réellement très bien.
Fourniture complète avec la prise IEC, les connecteurs RCA, les pieds et l'interrupteur.
Je recommande chaudement !
Merci Audiophonics !!!
This Lite Audio A28D box is ideal for designing a DIY audio system such as a power amplifier, preamplifier or DAC. Robust, with a 6mm thick front...
