Material
Diameter (mm)
Height
mm
mm
Alessandro C.
IAN CANADA PUREPI
Incredible power system for Raspberry PI and for ES9038 + FIFO Q7 II. Allows you to obtain a very clean power supply. Great...
Alessandro C.
IAN CANADA SHIELD PRO
It works very well and is certainly a clear improvement of the power supply of the raspberry PI as well as being an excellent...
Alessandro C.
IAN CANADA TRANSFORMER I/V
Great Audio stage that allows you to play digital music with the sweetness of analog. I am very satisfied
Aluminium feet
Aluminum shock & vibration and Spikes to deal with unwanted vibrations and avoid picking up avoidable noise in your High Fidelity audio devices. Stackable supports and discreet pieces according to your needs and the general aesthetics of your installation.
