Knurled aluminum foot Ø20x8mm Silver (Set x4)
This set of 4 feet is ideal for stabilizing a device while disconnecting it from an assembly to limit vibrations. The anodized aluminum feet are coupled with rubber bands to prevent the device from slipping, while damping vibrations. The load capacity of this set of feet is 10 kg.
Reference : 19247
9,50 €tax incl.
7,92 € tax excl.
Shipping date: 29-04-2025.
Knurled aluminum foot Ø20x8mm silver: Set x4
This set offeet is ideal for stabilizing a device while disconnecting it from an assembly to limit vibrations. The anodized aluminum feet are coupled with rubber bands to prevent the device from slipping, while damping vibrations. The load capacity of this set of feet is 10 kg.
Product typeAluminum foot
DimensionsØ20 x 8mm
MaterialAnodized aluminum + Rubber ring
Cylinder bore3.5mm
ColorSilver
PackageSold by 4
Diameter (mm)20.0
MaterialAluminium
MaterialRubber
Height8.0
This set of 4 feet is ideal for stabilizing a device while disconnecting it from an assembly to limit vibrations. The anodized aluminum feet are...
