AUDIOPHONICS HPA-Q250NC Power Amplifier Class D 4 Channel NCore NC252MP 4x250W 4 Ohm
The Audiophonics HPA-Q250NC is a four-channel amplifier based on two Hypex Ncore NC252MP.
4.5 / 5
By buying this product you get 109 loyalty points
Reference : 14356
1 090,00 €tax incl.
908,33 € tax excl.
Shipping date: 25-03-2026.
Audiophonics Workshop amplifiers range
Class D amplifier 4 channels NCORE NC252MP 2x250W 4 Ohm
The Audiophonics HPA-Q250NC is a four-way amplifier based on two Hypex NCORE NC252MP amplification module. This solution is ideal for audio installations requiring high power reserve and with advanced home cinema capabilities as well. The set offers high level sound reproduction to suit demanding speakers and to sonorize large listenning rooms or for studio applications requiring deep headroom without compromising on accuracy and audio message richness.
The set of components is integrated into a 100% Aluminum sober and robust housing with heatsinks to allow excellent heat dissipation. Its design also allows it to limit the impact of interference on the signal.
2x Hypex NCORE NC252MP amplifier module
Each channel of the amplifier circuit uses its very own Hypex NCORE NC252MP amplifier module. These high-performance class D amplifier circuits each provide a very comfortable power of 2x150W under 8Ω while benefitting from high efficiency typical in Class D amplifiers.
Its main characteristics are its flat frequency response regardless of the load impedance, its almost frequency-independent level of distortion and its ability to reject EMI interference. Its works with a self-oscillating loop controlled by phase shift only taking feedback at the speaker output into account.
2x Integrated SMPS Power Supply
Each of the two modules NC252MP NCORE has its own power stage. The latter consists of a switching power supply (SMPS) half-bridge controlled with synchronous rectification on the primary output rails. Compact, powerful and efficient, this power supply has been specifically designed to suit this amplifier circuit.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NC252MP module also has an overload protection system.
Connectivity
The MPA-S250NC amplifier has 4 x 3-pole XLR input on Neutrik NC3FDLX-M3 sockets. The amplifier output is made on Elecaudio BP-207 24k gold-plated speaker terminals with carbon finish. They accept banana plugs or forks for quick and easy connections.
A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button allows the device to be switched on.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Type of productPower Amplifier
ClassD
Number of Channelsx 4
Max. (@ 1kHz, 1% THD =)4x150W @ 8Ω
4x250W 4Ω @
4x180W @ 2Ω
Input4 x XLR balanced
Outputspeaker terminals
Trigger5-12V
THD + N0.0015%
SNR121dB
Output noise30μV
Imépdance output1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax power at 1.66V RMS
(2x0.83V RMS)
Supply voltage230V / 110V (automatic switch)
Dimensions413mm x 330mm (360 avec borniers) x 60mm
Weight5,9kg
Power cableInclued
InputXLR
OutputSpeaker terminal
Channel4
Amplifier chipHypex Ncore
Power (W)250.0
2 reviews
Plutôt bon
L'ampli est plutôt bon, je reconnais que la définition est meilleurs qu'avec mon crown XLS 1502 (plus de micros détails), par contre je ne suis pas bluffé par la différence qualitative, à l'écoute on gagne un peu c'est vrai dans les détails, , mais au vu des critiques et review sur les amplis hypex ncore je m’attendais à un gain qualitatif plus conséquent, je reste malgré tout satisfait de ce nouvel ampli qui s’intègre mieux.
This review has been posted for AUDIOPHONICS HPA-Q250NC Power Amplifier Class D 4 Channel NCore NC252MP 4x250W 4 Ohm
Insane value and perfermance
As the title says, insane value and perfermance! Compared to my much more expensive Emotiva amplifier this one sounds smoother which I didn't expect. In fact this Audiophonics amplifier sounds so good I placed an order for the 3-channel Purifi amplifier.
Regarding build quallity; one of best built amps I have held in my hands - built like a tank!!
 (4)
