Sounds perfect with my Arendal 1723 speakers.
By buying this product you get 189 loyalty points
This product has been replaced by the Audiophonics HPA-T450ET.
Power Amplifier PURIFI 1ET400A 3x400W 4 Ohm
We are proud to offer you the AUDIOPHONICS HPA-T400ET, a 3 way class D power amplifier based on three PURIFI 1ET400A modules. This ready-to-use version is aimed at audiophiles who want to equip themselves with a foolproof amplification solution, with a considerable power reserve as well as impeccable linearity. PURIFI modules are among the most rigorous Class D amplification solutions on the market, with measured performance that is simply outstanding.
The ensemble offers a high level of sound reproduction that will be suitable to accompany demanding loudspeakers, to soundtrack large listening rooms or for studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
All the components are integrated in a sober and robust 100% aluminum case with openings and radiators to promote heat dissipation. Its design also allows it to limit the impact of interference on the signal.
The SMPS1200 is a very high efficiency power supply capable of developing a nominal power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by HYPEX to provide the 2 x 64V voltage needed to operate the most demanding amplifier modules.
This quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. In addition, the amplifier modules themselves have an excellent ability to reject power supply noise. The HPA-T400ET is therefore extremely insensitive to imperfections in the power supply and to voltage/current variations that can cause noise.
The amplifier module Purifi is driven by a controller module of our design.
A Audiophonics OPA1656 per channel is used, these are very low distortion AOPs offering the greatest transparency with a very low THD. They are mounted on socket allowing their replacement if necessary
To suit all applications, we've opted for four gain settings, switchable via jumper on the underside of the unit.
This device is supplied set for a 230V AC supply voltage. If your mains supply is 110V AC, please select this voltage using the switch on the underside of the device before plugging it in.
Designed for easy integration, the HPA-T400ET has three XLR inputs and three RCA inputs. These inputs are ideal, especially for a home cinema audio system, in order to install a stereo system with an additional center channel. On the output side, BP-207 Carbon / 24K Gold insulated terminals Ø5.5mm ensure an excellent connection with the speakers. A trigger module (Jack mono) allows the amplifier to be switched on automatically from a distance. The latter is compatible with voltages from 5 to 12V.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Characteristics | |
Type | Power amplifier |
Output power | 8Ω @1%THD : 227W 4Ω @1%THD : 425W 2Ω @1%THD : 450W |
THD+N | PO=1W, f=1kHz 0.0007 % PO=10W, f=1kHz 0.00026 % PO=100W, f=1kHz 0.00015 % PO=1W, f=20-20kHz 0.0007 % PO=10W, f=20-20kHz 0.00029 % PO=100W, f=20-20kHz 0.00017 % |
IMD (CCIF) | PO=1W, f=18kHz+19kHz 0.00025 % PO=10W, f=18kHz+19kHz 0.00022 % PO=100W, f=18kHz+19kHz 0.00027 % |
IMD (DIM) | PO=1W, DIM30 0.002 % PO=10W, DIM30 0.002 % PO=100W, DIM30 0.002 % |
Noise floor | A-weighted 11.5 µV |
Dynamic range | A-weighted 4Ω 131 dB |
SNR | A-weighted 4Ω 131 dB |
Frequency response | RL= 8Ω, f= 20-20kHz ±0.01 dB RL= 4Ω, f= 20-20kHz ±0.01 dB RL= 2Ω, f= 20-20kHz ±0.01 dB |
Output impedance | 1kHz, Iout=1A 0.07 mΩ 20-20kHz, Iout=1A <0.65 mΩ |
Input impedance | XLR 100kΩ Bypass : 4.4 kΩ |
Power supply | 230V (110V on demand) |
Trigger | 2x trigger 5-12V on jack 3.5mm connector |
Dimensions | 413 x 322 x 60mm |
Weight | 6.25kg |
Idle power | 0.1W |
Power cable | Included |
Input | XLR |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | 3 |
Class | Class D / T |
Amplifier chip | Purifi 1ET400A |
Power (W) | 400.0 |
Remote Control | No |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Anders C.
Owen M.
