AUDIOPHONICS MPA-M500NC Power Amplfier Class D Mono NCore NC500MP 1x500W 4 Ohm
We are pleased to introduce the MPA-M500NC, a mono power amplifier based on a NCORE NC500 amplifier module.
By buying this product you get 47 loyalty points
Reference : 14319
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 29-04-2025.
Audiophonics Workshop amplifiers range
Audiophonics MPA-M500NC
Class D amplifier mono NCore NC500MP 1x500W 4 Ohm
AUDIOPHONICS MPA-M500NC picture
We are pleased to introduce the MPA-M500NC a mono power amplifier based on a NCORE NC500MP amplification module . This unitis an affordable solution with formidable amplification power (up to 500W). It is suitable for any large listening room and for all projects requiring massive power.
The module is integrated in a robust 100% aluminum housing with vents. The latter has a simple design and excellent ability to block interference while effectively dissipating heat.
Amplification module NCORE NC500 MP
AUDIOPHONICS MPA-M500NC interior picture
The Hypex NCORE NC500MP is a high efficiency 500W amplification circuit with low output impedance, low distortion and low noise. ll carry its own switching power supply unit with synchronous regulation.
As most of the amplifiers based on NCore, the frequency response is independent of the load and EMI are strictly controlled, which significantly limits the distortion.
All internal wiring connector uses OCC 2.5mm² conductors to enjoy excellent conductivity and preserve all of the signal subtleties.
Alternable input on RCA and XLR
AUDIOPHONICS MPA-M500NC connectors
The power amplifier has an RCA port input (mono) and a XLR input (balanced mono).
The RCA base is plated with gold 24k plastic and has a heat resistant capsule.
The XLR connector is a high quality Neutrik connector with metal latch and gold-plated conductors.
A two position switch toggles the XLR and RCA input with ease. This allow to connect two different preamps and alternate input sources.
High quality speaker terminals
AUDIOPHONICS MPA-M500NC speaker terminals
HPA-S500NC uses a pair of 24K gold-plated terminals.
These terminals are designed to accept banana plugs up to 4mm.
They are also compatible with bare wures thanks to a lockable ⌀5.3mm notch with screws.
Trigger 5-12V
A power trigger brings the comfort of an ignition sequence and allows a complete integration into your audio system.
The input power supply is a IEC14 socket. An angled power cable  3x1.5mm²- 1.8m is included for this purpose.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
TypeClass D power amplifier
Channelx1 (mono)
Inputs1x RCA
1x XLR - 3 poles
Technologyncore
Power1x400W under 2Ω @ 1kHz THD = 1%
1x500W under 4Ω @ 1kHz THD = 1%
1x270W under 8Ω @ 1kHz THD = 1%
1x 135W @ 8Ω 10Hz-20kHz THD = 0.006%
1x 250W @ 4Ω 10Hz-20kHz THD = 0.006%
THD + N0002-0006%
SNR124dB @ 10Hz-20kHz
Output noise40μV
Frequency response0 / -3dB: 10Hz - 50kHz
trigger5-12VDC
Power supply100-240V
automatic detection of the input voltage
Gain25.5dB
input sensitivityPuissance maxi à 2.35V RMS
XLR : 2x1.17V RMS
RCA : 1.17V RMS
Power consumption max1300W
Efficiency (full power)92%
load consumption13W
FrameSandblasted aluminum
Total dimensions (WxDxH)145 x 355 x 64mm
Weight1.8kg
Power cableIncluded
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipHypex Ncore
Power (W)500.0
4 reviews
Excellente musicalité
Très satisfait de ce bloc mono Hypex Ncore 500 MP
Le son est excellent, aucune distorsion à tous niveaux sonore où il reste extrêmement nuancé ce qui n'est pas toujours évident avec certains amplis en classe D.
Remarquable amplificateur que je ne peux que conseiller.
This review has been posted for AUDIOPHONICS MPA-M500NC Power Amplfier Class D Mono NCore NC500MP 1x500W 4 Ohm
Fait le job !
Acheté pour alimenter une centrale Focal CC1008 Be, il se balade avec présence et impact !
Il ne chauffe pas en étant totalement silencieux, juste un très très léger petit souffle en collant l'oreille au tweeter Be donc rien à signaler.
A noter que le trigger fonctionne très bien derrière mon Marantz AV8805 sans aucun bruit, ni ploc à l'allumage.
Highly recommended
I also use this power amplifier in an active speaker system to amplify the bass frequency speaker. I can only say that the result is totally realistic bass frequencies. I have also done tests as a medium and high frequency amplifier and the result has surprised me very positively, not so much as to replace a power amplifier with 300B valves and premium components, and although the timbre and especially the voices of the power stage of vacuum valves are noticeably superior, the scene and speed seem outstanding to me, especially for the price of these stages. I advise your purchase without reservation.
Impact et densité
Livré en avance par rapport à la date prévue.
Boitier bien fini et ne chauffant pas.
Utilisé, dans un système multi amplifié, pour le registre grave ( inférieur à 120 Hz).
Remarquable qualité d’impact, de densité, de définition et de tenu des HPs et ceci jusque dans l’infra.
A conseiller sans réserve pour la reproduction de ce secteur !
