HIFIBERRY AMP4 Amplifier Module
The HiFiBerry AMP4 is a DAC/amplifier designed to work with the RaspBerry Pi. It features a TI TAS5756M chip. This chip is a stereo amplifier integrating a Burr-Brown DAC. It delivers up to 2x 30W of power and supports 44.1-192kHz (16-32bit) streams. This amplifier module works equally well with 4 ohm or 8 ohm speakers.
Reference : 19117
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 24-10-2025.
HIFIBERRY AMP4 Class D Amplifier Module TAS5756M for Raspberry Pi 2x30W
HIFIBERRY AMP4 picture
The HiFiBerry AMP4 is a DAC / amplifier module designed to work with the RaspBerry Pi. It features a TI TAS5756M chip. This chip is a stereo amplifier integrating a Burr-Brown DAC. It delivers up to 2x 30W of power and supports 44.1-192kHz (16-32bit) streams. This amplifier module works equally well with 4 ohm or 8 ohm speakers.
We recommend powering this module with a voltage between 12V and 20V for use with a 4 ohm load, and 12V to 24V for an 8 ohm load. The HifiBerry AMP4 is capable of powering the Raspberry PI, so an additional 5V supply is not required. However, it is not designed to power USB peripherals or other hardware that would require too much power and risk making the system unstable.
Finally, if you wish, this module can be used with HifiBerry's ADD-ON BOARD DSP to enable advanced digital signal processing possibilities. You can also bridge the outputs of both AMP4 channels.
If the software you're using doesn't provide AMP4 as an output option, you'll need to use the HiFiBerry DAC+ driver.
RaspBerry Pi compatibility: A+ / B+ / 2B / 3B / 3A+ / 3B+ / 4B / 5 / Zero / Zero W / Zero WH / Zero 2 W / Zero 2 WH
A single power supply is sufficient to power both the Raspberry Pi and the AMP4, directly via the latter.
Product typeDAC / amplifier module for Raspberry Pi
Amplifier/DAC chipTAS5756M
InputGPIO
Outputs1x Channel 1 on screw terminal
1x Channel 2 on screw terminal
Other connectors1x DC jack 5.5/2.1mm for power supply
1x Screw terminal block for power supply
Compatible speaker impedance4-8 ohm
Supported sample rates24-32bit 44.1-192kHz
Max. output power2x 30W
THD+N< 0.02% (typical, output power 0.1-10W)
SNR 104dB
Frequency response20Hz-20kHz (output filter characteristics according to specific speaker parameters)
Recommended operating voltage12-20V
Maximum operating voltage24V
Typical output power per channel14W (Vsupply=12V, Rspk = 4Ohm, THD+N <0.1%)
18W (Vsupply=18V, Rspk = 4Ohm, THD+N <0.1%)
20W (Vsupply=24V, Rspk = 4Ohm, THD+N <0.1%)
8W (Vsupply=12V, Rspk = 8Ohm, THD+N <0.1%)
17W (Vsupply=18V, Rspk = 8Ohm, THD+N <0.1%)
28W (Vsupply=24V, Rspk = 8Ohm, THD+N <0.1%)
Max. output power per channel15W (Vsupply=12V, Rspk = 4Ohm, THD+N <10%)
30W (Vsupply=18V, Rspk = 4Ohm, THD+N <10%)
44W (Vsupply=24V, Rspk = 4Ohm, THD+N <10%)
10W (Vsupply=12V, Rspk = 8Ohm, THD+N <10%)
20W (Vsupply=18V, Rspk = 8Ohm, THD+N <10%)
38W (Vsupply=24V, Rspk = 8Ohm, THD+N <10%)
Recommended voltage per impedance12V-20V / 4 ohm
12V-24V / 8 ohm
Configurationdtoverlay=hifiberry-dacplus
Power supply12-24V DC via jack DC 5.5/2.1mm
Package1x HiFiBerry AMP 4 amplifier module
The HiFiBerry AMP4 is a DAC/amplifier designed to work with the RaspBerry Pi. It features a TI TAS5756M chip. This chip is a stereo amplifier...
