3E AUDIO 480-1-29A PFFB Mono amplifier Module
This 3E Audio 480-1-29A amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W into 2 Ohm (@ 1% THD+N, 1kHz) while maintaining premium sound quality.
3.5 / 5
Reference : 18568
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 02-04-2025.
3E AUDIO 480-1-29A PFFB Mono Class D Balanced Amplifier Module TPA3255 1x480W 2 Ohm
Photo of 3E AUDIO 1CH amplifier module
This 3E Audio 1CH amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W into 2 Ohm (@ 1% THD+N, 1kHz) while maintaining premium sound quality. It incorporates an advanced feedback design as well as a high-speed correction system (PurePath™ Ultra-HD). The integration of these technologies enables the 3E Audio module to maintain a very low level of distortion across its entire audio band.
In addition to this outstanding audio performance, the energy efficiency of this TPA3255 module is very high thanks to the use of 85mΩ MOSFET transistors. In other words, the components in this 3E Audio module enable it to deliver substantial power while maintaining very low levels of noise and distortion, offering clear, transparent sound reproduction while maintaining a compact form factor.
This makes the 3E Audio module ideal for use when mounting a powerful DIY amplifier, for use with hard-to-control loudspeakers or a powerful subwoofer, for example.
Test du 3E Audio 480-1-29A PFFB par Audio Science Review (Amir)
" Je ne sais pas ce qui m'impressionne le plus : le TI TPA3255 ou les compétences techniques de 3E Audio. C'est un module incroyablement performant pour ce niveau de prix. Bien sûr, il faut tenir compte de l'ajout d'une alimentation et d'un boîtier performants, mais on ne peut s'empêcher d'être imprresionné. "
Logo Audio Science Review
Product typeMono amplifier module
Amplification typeClass D
Amplification chipTI TPA3255
Output power1x 480W 2 Ohm (@ 1% THD+N, 1kHz)
1x 600W 2 Ohm (@ 10% THD+N, 1kHz)
1x 280W 4 Ohm (@ 1% THD+N, 1kHz)
1x 350W 4 Ohm (@ 10% THD+N, 1kHz)
Dynamic range11dBA
THD+N< 0.01%
Efficiency90% (4 ohm)
Noise level< 85uV (AES17,A-weighted)
Power supply voltage range24V - 51V DC (UVP : 24V)
Dimensions105 x 90 x 38.5mm
Package1x Mono 3E Audio 1CH amplifier module
InputPCB Connector
OutputSolder pad
Channel1 (Mono)
Amplifier chipTPA3255
Power (W)480.0
Download
2 reviews
baja corriente
Es mucho peor que la 3e PFFB stereo que conservo, compré 2 mono PFFB con fuentes de alimentación lineal de 300va cada no reguladas...un desastre, no tenia ni graves ni dinámica, creo que esta internamente puenteada mal el mono de manera que si la impedancia mínima de la 3e estéreo PFFB ya son 4 ohm y necesita cajas muy facules tipo mark audio, Klipsch...la monk es para IMPEDANCIA MINIMA de +8ohm (si) por tanto con casi todas las cajas sonara sin graves ...pero si tus cajas son de impedancia mínima 8ohm, compralas, mide genial
This review has been posted for 3E AUDIO 480-1-29A PFFB Mono Balanced Class D Amplifier Module TPA3255 1x480W 2 Ohm
Excellent, 3 fois deux !
une paire de blocs mono réalisée avec ces modules: résultat magnifque , très musical . encore meilleur que le module stéréo (déjà excellent) du même fabricant. c'est peu dire!
 (3)
This 3E Audio 480-1-29A amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W...
