3E AUDIO Amplifier Board Stereo Class D Balanced TPA3255 2x 225W 4 Ohm
This stereo amplifier module integrates a TPA3255 amplifier chip, allowing it to develop a consequent power of 2x 225W under 4Ω (1% THD+N) while taking advantage of the high efficiency inherent to its Class D architecture. The careful design of the module allows it to display very good measurements, such as a background noise of 85µVrms or a dynamic range of 111dBA.
Reference : 14690
99,00 €tax incl.
82,50 € tax excl.
This product has been replaced by the new version, the 3E AUDIO PFFB Balanced Class D Amplifier Module TPA3255 BTL.
Module d'amplification 3e audio
Stereo Class D TPA3255 2x 225W 4 Ohm
Module d'amplification Stéréo Class D TPA3255 2x 260W 4 Ohm
The two inputs, on 3 pin 2.54mm connectors, can operate balanced or unbalanced, via a jumper adjustment. An auxiliary power supply output is also available, delivering 12V 0.2A, allowing to supply a preamplifier module.
The module may only be powered via a power supply input. Never connect both power inputs simultaneously.
RevisionB
Product typeAmplification module
Amplification chip1x TPA3255
Amplification typeClass D
ChannelsStereo (2)
Power output2x 225W @ 4Ω, THD+N 1%
2x 280W @ 4Ω, THD+N 10%
Input2x 3 pins 2.54mm connectors (switch balanced/single-ended)
OutputsSpeaker terminals
Auxiliary power supply output12V 0.2A
Speakers impedance4Ω ~ 8Ω
Dynamic range111dBA
Possible configurationBTL / PBTL
Noise floor85µV
Supply voltage24V ~ 48V
DimensionsExternal : 105x90mm
Distance between centres: 97x82mm
Maximum height: 40mm
Noise floor
Distortion
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)225.0
2 reviews
Trevlig krets
This review has been posted for 3E AUDIO Amplifier Board Stereo Class D Balanced TPA3255 2x 225W 4 Ohm
Trevlig krets men det finns många att välja
This stereo amplifier module integrates a TPA3255 amplifier chip, allowing it to develop a consequent power of 2x 225W under 4Ω (1% THD+N) while...
